Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Why does freezer automatically defrost and then stay in defrost no matter what we do?
  • chris_bitcon Oct 02, 2010
    this almost appears to be cyclical.... Happens every couple of months
  • GE Master
  • 43,501 Answers
The defrost timer/control board whichever you have is sticking in the defrost mode....replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 02, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Oct 02, 2010
    Yeah, it can be unpredictable... in fact I have a defrost timer sitting in the box for one of my refridgerators...the defrost timer stuck a month or so ago and I ordered the part but have not had to install it yet...it will go at the worst time possible I'm sure...
    heatman101
How do you know your Bosch Fridge Freezer needs defrosting?
Most home refrigerators share the same cooling coil for both compartments so in order to defrost the freezer that coil has to be disabled by pulling the plug. You havent mentioned the brand of refrigerator that you own but i am guessing that you have an automatic defrost. Can you hear a fan running inside the freezer compartment when the door is closed and the compressor in the back is running? If so your freezer will automatically defrost. The ice you probably see collects on the shelving or inside walls. Generally you can take the plastic handle of a screwdriver and gently tap the ice to get it to crack and fall off. Take care not to hit cold plastic parts or panels, they may crack or break. Otherwise I would get the model of the refrigerator and go to the manufacturers web site and post your question to get a positive answer. Good luck!
Jun 02, 2012 | Bosch Freezers
My freezer is automatically defrosting how do i stop this from running my food
Your freezer is SUPPOSED to automatically defrost. If it does not defrsot by itself,within a week so frost will be built up in the freezer no cold air will flow into the fresh food compartment and soon ALL the food in that compartment will be runied followed soon after by the stuff in the freezer. Unless something is wrong with the defrost cycle it defrst for 25 minutes every 72 hours (3 days) and make it so everything is in good working order and air flows as it is intended too. If your experiencing the defrost staying on for more that a hour at a time thats a problem but if it defrost about every 3 days all is well and should be left alone to work just fine as it was designed to do.
Aug 18, 2011 | Maytag MSD2756GES Side by Side...
Have a 550 model - the refrigerator part stays at 40 degrees no matter what the setting, freezer is working fine. I thought most refrigerators had a little adjustable opening between the two but I cant...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | Sub-Zero Bottom Freezer Refrigerator
Jenn Air freezer does not 'automatically defrost-side by side
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
Nov 29, 2009 | Jenn-Air JCD2295HES Side by Side...
The inside of the refrigerator is not staying cold. The freezer does stay cold. How do I fix the inside temperature so it will keep the food cold?
If any part of the automatic defrosting system isn't working, the evaporator will turn into an iceberg and no cold air will circulate into the lower compartment.
Possible causes in that case could be the defrost timer, the defrost thermostat ("bimetal"), the defrost heater, the defrost thermal fuse (if there is one), or the wiring and plugs connecting them.
Removing the back panel of the freezer compartment should reveal the iceberg and allow you to defrost it with a hair dryer or fan. Then you can get at the parts to test them (except the defrost timer, which may be down by the compressor).
Sep 27, 2009 | Avanti FF1101W Top Freezer Refrigerator
Refrigerator cools fine but the freezer does not. It stays at about 20 degrees f. It is a GE
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 16, 2009 | Refrigerators
Fridge is not cool
this is the problem of heater please replace it actually the matter is, behind the freezer panel there is a fan motor and behind it there is a coil in which the ice is formed. now the logic is, when the formation of ice increases then at that time the heater automatically defrost the ice this prevent from blockage of air pipe to the frizer.
Jun 07, 2009 | Kenmore 73752 / 73754 Top Freezer...
GE PROFILE FREEZER FAN STAYS OFF TOO LONG..ITEMS DEFROSTING
The fan stops during the whole defrost cycle, there is a bi metal control that determines the length of time the heater stays on. This could be the problem, if the heater stays on for the time that is allowed by the defrost timer it will get too warm in the freezer. the bi metal is located on the evaporator.
Feb 01, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Freezer is completely covered with white ice
sometimes a faulty door rubber can make the freezer work overtime. Does the door close firmly?
Oct 25, 2008 | Refrigerators
Samsung RS2630AWW freezer works/fridge does not
Chances are the fuse in the evaporator section is bad and won't go into defrost automatically.  Samsung refrigerators are junk!  Good luck getting anyone to service this one.
Oct 17, 2007 | Samsung RS2630AWW Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
142 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
