Question about Horizon Exercise & Fitness
Horizon T95 model TM202-1US. Majority of the console keys do not function. A few of the keys do produce a beep when pressed, but the majority of the keys do nothing.
3 Suggested Answers
  • 11800 Answers
SOURCE: " and @ have swapped buttons on the keyboard
Bad keyboard config - follow this
http://www.vistax64.com/tutorials/103844-keyboard-input-language.html
Posted on Jan 17, 2010
allinallelec
  • 407 Answers
SOURCE: IF6020 OFFICE FAX. ALL KEYS JUST BEEPING WHEN PRESSED
flash software.
Posted on May 30, 2012
Horizon Treadmill Ct5.1 turns on, displays nothing and beeps nonstop
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 26, 2016 | Horizon Exercise & Fitness
Hi,I Have removed Nissan sentra 1997 model 1.6i GSI thermostat, and dont know where the direction of the pin on thermostat must face and where to find bleeder screw
If the thermostat flange is horizontal it hardly matters which way the jiggle pin is placed as long as you put it in the right way up - with the wax capsule and return spring in the engine or hot side.
If the flange is mounted vertically the jiggle pin should be at the top as its function is to allow air or gas to escape.
Only a few "difficult" cooling systems are fitted with bleeder screws and the majority must be bled by running the engine and momentarily disconnecting a heater hose or similar. The majority of modern cooling systems are self-bleeding.
These days lots of workshops use a vacuum device and remove the majority of the air from the cooling system before allowing coolant to flow back in. This mostly eliminates the problem of air locks.
Nov 02, 2015 | 1997 Nissan Sentra
Horizon T91 Treadmill - Key Pad Troubleshooting
correct. If the console is not responding or some buttons do but others don't the membrane needs replacement.
Apr 02, 2017 | Horizon T92 - Treadmill
Horizon t207
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 08, 2013 | Horizon Exercise & Fitness
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
Sole treadmill won't go in to sleep mode
You need to go into the maintenance menu.
Take out the red safety stop key, hold down the "start", "stop" and "Enter" buttons, keep holding them down while putting the red key back in (a bit tricky), keep holding the keys down until you see "Maintenance menu" scrolling (this will happen as long as you didn't let go of the three keys).
Initially when you put the red key in it'll might show software version etc, after a few seconds it'll change to maintenance menu. Use the speed UP and Down buttons on the console or arm to scroll through menu until you reach "FUNCTIONS" press enter.
In the functions sub-menu, depending on what year model/software version it has, it should have a selection called "Sleep Timer" if so set it using up down keys to "ON". If your model doesn't have "sleep timer" listed (i.e. a newer model) it's now just called "DISPLAY" and in that case set it to "OFF". That should fix it.
Press Stop, to go back. If you want you can disable the key tone/training beeping as well in the "functions" sub-menu of the "maintenance menu".
To exit press stop repeatedly until you're back to the normal display.
Dec 30, 2012 | Sole Fitness F63 Treadmill
Nikon S210 pictures always out of focus
Is the lens clean? Are you pressing the shutter button half-way and giving the camera a chance to lock in the focus (it will beep) before pressing the rest of the way? Do you actually move while pressing the button? Try taking a few pics while the camera is on a tripod or a firm surface to eliminate movement.
Mar 27, 2010 | Nikon Coolpix S210 Digital Camera
Cant find model p52937sg
from "Wiki.Answers.com":
This is what worked for me:
Manual Code Search and Entry
1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Good Luck
Jack
Feb 21, 2009 | RCA RCR311B Remote Control
Tv vcr combo
Good Luck
Aug 15, 2008 | RCA RCR311B Remote Control
Exercise & Fitness Logo
114 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
