Question about Toshiba 40H80 40" Rear Projection Television
I have oil coming out of 1 of my tubes what does that mean and what kind of oil is it cause it looks like baby oil?
  • 1,476 Answers
P1407glover,
The oil that you saw is really water with some additives. It is used to cool the CRTs. They are run very hard to produce enough light to make a good picture and without the coolant the tubes would be destroyed. The bad news here is that unless the leak is found and fixed and the coolant replaced the unit will fail.
First of all turn the set off and do not use it. If you have no skills that would allow you to find the leak and fix it and replace the coolant call a reputable electronic shop and have a technician come and fix the unit.
The best fix would be to replace the tube. Fixing it is really not an option. If you replace it and the set is older there may be a problem balancing the tubes but a technician should be able to tell you what your options are.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Oct 02, 2010
Testimonial: "Thanks so very mush you made me very happy with this news and i found the leak."
  • Douglas Ross Oct 02, 2010
    so now that i found the leak and very little came out what can i do to fill it just add water?
  • Kim Yearick
    Kim Yearick Oct 06, 2010
    p1407glover,
    You must use a special solution of optical grade coolant. It is available from most electronic supply websites.http://www.mcminc.com has it as well ashttp://www.encompass.com . At the top of the CRT there is a filler port . Do not overfill it. There should be some space for expansion. Look at the red and blue tubes to determine the level.
    Thanks for using FixYa and for the great rating!!
    hardrocko
What's your question?my Isuzu 4ja1 engine .my problem is the oil comes from deep stick
i think you mean
when running the engine
the DIP STICK seal as it fits the dip stick tube end. leaks oil
this a bad PCV valve.
excess crank case pressures.... cause by not doing service on car.
or worse a very worn out engine with huge blow by gassed.
is engine miles high? over 300k? miles?
or the dips stick seal there is bad.... looking at it tells you that.
Sep 20, 2015 | Isuzu Cars & Trucks
Iwhat does it mean when check engine light comes on and it says the cam shaft position actuator
Means the camshaft position sensor has moved or covered in muck and oil or come loose or it is broken.
Aug 25, 2014 | Vehicle Parts & Accessories
Breather tube throwing oil into carb
Oil coming via the engine breather can mean a worn engine, it could be as simple as an over filled sump, or the breather valve itself is not working, the breather valve allows the crankcase pressure out of the engine.
Apr 20, 2012 | Cub Cadet Garden
Hello , we just bought a new home defence pump shot gun and we can load 5 shells into the magazine but it will not load a shell into the champer when we operate the pump.
check the elevator and make sure its working properlly and thsat its no damaged, jammed up, or something blocking it. unload your shotgun fisrt.
Feb 12, 2011 | Mossberg Marlin Rifle 992m,989,mossberg...
I have a flat tire; we have replaced the inner tube once already--How do I get a new tire?
Before just replacing the tyre (if it's still OK), a flat may be caused by a sharp object sticking through the tyre, puncturing the tube. Carefully check the inside surface of the tube with your fingers for sharp objects.
The Freestyle 4 uses generic 12" tyres but the thread may be quite specific. The stroller may have come with 'slick-type' tyres that are no longer available. The newer Freestyles come with these tyres:
http://www.babycare.nl/tyre-125x225-for-pushchair-buggy-stroller-p-1868.html
I hope this helps.
With kind regards,
Erwin de Raad
Babycare.nl
Sep 15, 2010 | Quinny Freestyle 4 Marina Stroller
Snapper 25 hp (kohler engine) mower
When checking the oil donot put dip stick clear in just let it set on top then pullit to check oil.rreplace it and tighten. Your putting to much oil in it.
Apr 30, 2010 | Ford Tractor 8n Front Emblem
My picture on my philips rear projection 51PP9100D/37 is awful and very hard to see...what do I need to fix?
HELLO: I HAVE REPAIRED MANY OF THE PHILLIPS AND MAGNAVOX PROJECTION TVS BY SIMPLY EXCHANGING THE PICTURE TUBE COOLANT INBETWEEN THE TUBES AND THE LENS THERE ARE SEALED CONTAINERS THAT HAVE A MINERAL OIL COOLANT IN THEM THEY GET CONTAMINATED BY SOME KIND OF POSSIBLE BACTERIA OF SOME KIND ESPECIALLY THE BLUE LEAVING YOU WITH A SOMEWHAT FUZZY PICTURE REDISH YELLOW USUALLY. YOU WILL SEE WHAT I MEAN IF YOU REMOVE THE FRONT OF THE TELEVISION SCREEN AND LOOK INTO THE TUBES WHILE THEY ARE RUNNING. TO PROPERLY REPAIR THIS PROBLEM YOU HAVE TO REMOVE THE TUBES IN MOST CASES OR CARFULLY SPLIT THEM FROM THE LENS ASSY BEING CAREFUL OF THE OLD FLUIDS INSIDE. CLEAN THE INSIDES WITH WINDEX AND RE ASSY WITH NEW FLUID . I HAVE USED CLEAR MINERAL OIL FROM THE DRUG STORE TO REFILL COOLANT. I HOPE THIS HELPS FROM RUSTY AT RVANS@NETZERO.NET
Jun 07, 2009 | Philips Televison & Video
Wheel grease for inglesina stroller
Use 3-IN-1 machine oil -- comes in a squeeze can at hardware sotre.
Apply oil to wheel axles/bushings, etc.
May 27, 2009 | Inglesina Zippy VG6 Umbrella Stroller
Baby Trend Double jogger
Just take it to your local bike shop. They should be able to fix it. The wheels/tires are basically small bicycle wheels/tires.
Nov 12, 2007 | Baby Trend Expedition Double Jogger
Toshiba 40H80 40" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
