Question about Canon PowerShot A470 Digital Camera
My camera battery died while I was shooting and the lens was out_ new batteries but now I am getting a lens error message!_ the lens will not retract! help!
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Oct 02, 2010
Shooting is not possible, turn the power switch to off and on or reinstall the battery
Hi there :the Error 99 is a comunication error between camera body and lens .are you using Canon lens?Try the camera body with a/another Canon lens in Camera body and try the lens on another Canon camera.With this troubleshoting you can know if the camera body is failing or lens is failing.I hope this information will help you.
Nov 29, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I have a Nikon Coolpix L22. I was taking a picture and all of a sudden I got a lens error message. now, yhe camera is totally dead.
If the camera will not turn on, you probably have a bad battery. Replace the battery with a new one and try again. It is possible that the battery was almost dead when the lens tried to adjust and this may have caused the lens error message before the battery completely died out. Else you will need to send the camera in for repairs.
Aug 03, 2011 | Cameras
Error message F-- Nikon D90 w/kit lens 18-105mm
correct - i need to get a good grip on the lens and click it to connect to the body
Jun 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens error
This can work with CoolPix S10
1) Remove battery.
2) Replace Battery (Insure it is fully charged)
3) Press the Shooting/Preview button and keep pressing it while you press the power on button. This tells the camera to go into PREVIEW MODE without checking the lens. See if you can preview a few photos and that it works in preview - If it does NOT I cannot help you here.
4) If the Camera Works in Preview mode then press the Shooting/Preview button to put it back into "Take Photo Mode".
5) There can be a delay but it starts up without the lens error.
6) Make sure the ZOOM IN and OUT works and in most cases if the lens operates then you can take a photo. If the Zoom in and Out does not work you have a jammed lens.
7) If the LENS is Jammed AND it is OUT of warranty you 'might' want to tap the lens barrel against your palm. I have found when you remove the battery you can gently tap the lens into telephoto mode by tapping the back of lens assembly into your palm.
May 28, 2008 | Nikon COOLPIX S10 Digital Camera
Camera turns off after lens comes out in shooting mode.
I'd recommend that you stop banging or fiddling with the lens as it does not sound like a lens error (if it were so, you'd still get an error even in review mode). Instead it sounds like the brand of batteries that you're using may not be providing sufficient power.
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Most retailers sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
May 15, 2008 | Canon PowerShot A530 Digital Camera
Zoom error
I had sent my camera in for the same issue and they did nothing to help with it. Seems to happen when battery gets low or dies, lack of on-screen battery meter doesn't help. Typically have to manually twist the lens to close it or open it after fresh batteries installed and then seem to fix it.
Apr 08, 2008 | Fuji FinePix E550 Digital Camera
Lens Error
It sound like your lens is either jammed or the motor that causes the lens to open has a problem. First try spraying a can of compressed air around the lens while you turn it on. Also make sure that you are using high output batteries. Digital camera's require high capacity batteries to operate properly but if you are getting a error message then that means that the camera is turning on. Usually if you use regular batteries the camera will just cycle on and off but the lens will come out and go back in. Has this camera been dropped?
Mar 17, 2008 | Vivitar ViviCam 5386 Digital Camera
ZOOM ERROR
What just started? The camera? Do you have fully charged batteries? Did you check the manual?
Dec 30, 2007 | Fuji FinePix S7000 Digital Camera
FEE error message
To get rid of the pesky fEE just set your lens to f22 or f16 ( depending on what lens you have ) and that is all. You might also want to lock this setting in ( if it is a Nikon lens then the lock is on the side just above the lens aperture ring.
Dec 07, 2007 | Nikon N55 35mm SLR Camera
Canon PowerShot A470 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
