Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Kenmore washing machine discharge,but will not spin
Wondering if this is a huge problem or if it is as simple as replacing a belt. This is on a top load kenmore model # 11022642100 Serial cpo579700. I have tried to take the back off, but it only wants to tip forward, is there away to get better access?
    President:
  • 1,314 Answers
Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain, and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps. Then facing the washer locates the two screws. They will either be in the front or rear of the control panel or back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when you’re done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. Take them and clamp the hose coming from the tub but it’s not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on May 27, 2008
No spin motor moves top loaded samsung washing mechine
You may need something as simple as a belt if its a belt drive machine...Hope this helps Shannon
Mar 07, 2012 | Washing Machines
I have an elite model 11024942301 and the spin cycle won,t work
check your lid switch. If you hear the motor running, your problems can be a coupler(Whirlpool), belt, clutch, or even a transmission problem.
Nov 10, 2011 | Kenmore 24032\24036 Top Load Washer
I have a top loading washer model #4420716...it will spin but make very loud noise I am wondering if a belt or something broke...it sounds like the basket is hitting the sides of the washer.
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Check and let me know.
Thanks.
Jun 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine not spinning immediately on spin cycle,
prob find your belt has a tensioner, and prob find its come loose or broken, remove back, inspect, replace or secure tensioner and test keeping fingers away, or could be the belt has partly broken apart... also it may be one of the sprockets spinning on its axel, inspect to diagnose even by spinning drum by hand, parts broken are obviously replaced and your done... These machines are usually quite simple once you have the cover off but be very care ful with water and live power, you should beable to see if anything is faulty with the power off so see how you go. Goodluck, Chas
Jun 08, 2009 | Kenmore Washing Machines
My Kenmore washing machine, top load, will not
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
May 06, 2009 | Kenmore Washing Machines
Tub won't spin
Your direct drive coupling is broken. Follow the instruction in this video for repair.
Apr 21, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Elite top loader washing machine is not spinning well
USUALLY ITS A BROKEN COUPLER TOP 15 YRS AND NEWER DO NOT HAVE BELTS
Nov 29, 2008 | Kenmore 24032\24036 Top Load Washer
the belt is slipping if this model still has belts.
lean/tilt it back and look under for belts.
its the belt in the center
Feb 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top-loading washer won't spin
take cabinet off, from the front, control panel first, then lay on back and take water pump off then motor off and you will see where the couple goes on. Pretty simple job how ever you may be missing some transmission clutch plates that will make it grab and stop with a bang like that.
Dec 21, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
108 people viewed this question
Dan Webster
Dan Webster
Sal De
