Question about Dryers
Is overheating. I checked my vents and this is not the problem. What else could be the problem
  • 37 Answers
The heating element is going bad its a coil spring looking thing that is in the back make sure you unhook dryer before removing any covers
Posted on Oct 02, 2010
My kenmore elite he5 dryer is overheating
High temp sensor could be defective
Feb 10, 2018 | Kenmore Dryers
Kirkland gas dryer heat input vent is charred. Is this a problem of overheating?
Overheating is always caused by insufficient airflow coming OUT of the dryer. Check the wall vent for blockages and the vent flaps work. Check all the pipe work for lint build up and birds nests. Run the dryer with the hose off and the air should be very strong. If not, then you need to investigate inside the machine.
Jun 04, 2017 | Dryers
I have a 6 year old whirlpool dryer (GEW9250PW0) that needs the sensor for the air flow and heat to be replaced approximately every 6-8 months. The repairman (certified) replaced this part last monday and...
Barone1997,
By-passing any devices on a dryer or any other appliance is risky as doing this can void warranties and could create a dangerous condition.
If then dryer is overheating, check the venting for excessive lint build up and clean the vent as well as any hoses or other vent piping. Also check and clean the lint screen frequently.
There is also a limit to the length of the vent line and the number of bends that the vent line should have.
It's possible that the dryer vent may be damaged or kinked, so check that too.
Apr 18, 2011 | Whirlpool Dryers
Dryer drum loose not lining up properly making a huge thumping sound
Identification of Dryer Problems
Signs that an electric dryer may need some repairs include the dryer not heating, clothing not drying fast enough, overheating of the dryer, the door not locking shut and the dryer not starting at all. Any of these are signs of an underlying problem that can usually be solved without the help of a repairman.
Effects of Dryer Issues
If an electric dryer doesn't heat properly, it prevents the clothing from becoming dry in most cases. Restricted venting can cause clothing not to dry fast enough, as the dryer will cycle the heating. Overheating dryers can ruin clothing or cause burns. If the door on a dryer wont close, it is impossible to get any laundry dried. A dryer not running at all can be very frustrating and lead to owners needing to use a laundromat.
Considerations for Solving Common Problems.If the dryer wont heat up, owners should check the circuit breaker to see if it's down. The voltmeter at the wall plug should read 240 volts. Checking the power cord can show owners if the wires are burned where they meet the dryer.Clothing not drying fast enough and overheating are signs of restricted venting. Removing the vent hose from the dryer can help owners decide if this is the cause of clothing not drying. If the hose is removed and the dryer runs normally, the vent should be cleaned.White plastic or thin foil ducts can also lead to overheating. Only metal ducts should be used with dryers. Kinks in the vent hose can also lead to heating issues. Overheating can also be caused by a shorted heater coil, a bad operating thermostat or worn drum seals.If the door on an electric dryer will not close, it is usually a problem with the door catch. This can be solved easily by purchasing a replacement door catch for the dryer.
When a dryer wont run, it could be a number of issues. The circuit breaker may be down or the wires at the plug may be burned. It may be an issue with the door switch. The door switch should click when closed. The thermal fuse should be checked for any issues.
Preventing Dryer Problems
The electric heating element, thermostats, fuses and thermal cut-off should be checked regularly for continuity. Dryer vents should not exceed 18 feet without a helper blower in the duct. Vents that are run vertically need to be cleaned out once a year. A meter can be purchased and used to diagnose problems with your electric dryer.
Warnings and Tips.Inexperienced people should never try to fix electrical problems at home. A professional should always be used if dryer owners suspect a more serious problem. Dryer owners can purchase kits to make cleaning dryer vents easier.
Mar 11, 2011 | Whirlpool Dryers
My daughter's sony vaio vgn-cr420e turns off suddenly and randomly while in windows. battery is currently not in and no overheating is present, which i understand could cause such a problem. however,...
It is very hard to tell when the processor is overheating. The laptop may not feel hot at all. If it is an overheating problem, there could be two different causes. One, the fan may be failing or completely failed. Two, there could be dust buildup on the heatsink which you would not be able to see by looking in the vents. The laptop would need to be disassembled to check the heatsink for the buildup. An easy way to check to see if the fan is working is to turn the computer on, let it run for just a few minutes and if the fan is not blowing hard enough for you to feel it with your hand, try holding the vents up near your face to see if you can feel any air flow.
Aug 19, 2009 | Computers & Internet
1998 Chrsler Sebring coolant gurlges - now overheating
yes some systems have to be burped or the boil over can occur in the motor and cause head gasket issues..at 195k i think you should check the system for leaks and thermostat if it is opening at right tempatures or is slow..plus the vented cap on your radiator check with vacuum gauge if it holds about 12-14 psi before it vents...
May 07, 2009 | 1998 Chrysler Sebring
Engine overheating and blowing fluid out of vents
fluid coming out of the vents indicates a faulty heater core, but this does not explain the overheating problem. The blown heater core may only be the result. Check the coolant level.Check for coolant leaks primarily at the water pump. Check the thermostat by insuring both hoses to and from the radiator warm up. Check for foamy oil or white smoke from the exhaust indicating a blown head gasket or cracked head. Check to ensure your cooling fan is working.
Jan 03, 2009 | 2003 Nissan Altima
Toshiba Laptop overheating
Your Problem is of overheating the unit.
Pls check the Air exhaust of the Laptop. The fan may be blocking air and may be causing the processor hot. It's better to
service the Laptop if problem still persists.
Viren
Jul 17, 2008 | Toshiba Computers & Internet
Dryer overheating.
It ma be an indication of restricted airflow in the venting.
The machine is warning you that the exhaust vent airflow is insufficient. Check the exhaust hose in the rear of the machine and make sure it it not crushed or kinked. The vent pipe should be rigid metal not flexible foil or flexible plastic. If everything in rear looks OK, check the outside vent hood for any blockages. If everything checks out, the exhaust system may need cleaning. Cleaning kits are available at most home improvement centers. or at this website: www.linteater.com
Jun 22, 2008 | Whirlpool Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
