Question about Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW
Freezer not Freezing
Problem 1: I have an ongoing problem with the children not shutting the door and everything thawing out and having to be thrown away. Any ideas or solutions for this problem?
Problem 2: Last night, I noticed it was not freezing. It was about the temp of the refrigerator. There was an ice build up all across the bottom. I scraped it all out and noticed there is a black line across the back. I'm not sure if that is an air return vent or something important, but I got as much of the ice out as I could, but didn't want to harm that area. Could that have been the problem? It's freezing this morning, but I don't want to have this occur again.
  • adasha May 26, 2008
    So that black strip at the bottom in the back needs to be free of ice for the air return?
    President:
  • 1,314 Answers
Ok promblem 1 raise th front levelingm legs so that when the door is released from opening 1/3 of the way it shuts its self promblem 2 if the ice gets so thick it blocks the air intake of the freezer it cant cool your defrost drain is blocked its under the back panel in the freezer and needs to be cleared
Posted on May 26, 2008
Why haier freezer is beeping
Either way if you had the doors opened a lot, it should like you probably have frost build up preventing proper air flow. You'd need to pull everything out of the freezer and remove the lower back panel inside the freezer. If there is frost build up, you'll need to use a hair dryer to thaw all the frost out. The unit will continue to beep until the set temperature (0 and 38) are reached so that could take a while even after thawing out all the frost build up.
If removing panels sounds like more than you can handle, you can always unplug the unit for 24 hours and leave the doors open to allow the unit to defrost on it's own.
Oct 16, 2016 | Haier Freezers
Old whirlpool upright freezer. door left slightly ajar.light on inside. Rubber around door warm. won't seal.some things starting to thaw.shut door.should I do anything else
Seal needs to be replaced around door. Make sure magnetic strip is tight against sides of refrigerator, even if you have to cut the outside so it lays flat against the sides.
May 03, 2015 | Whirlpool Freezers
FFB6187
Try rearranging all items inside fridge and freezer so that air may circulate around all items easily and then check seals on doors and ensure doors are closed completely and not leaking cold air. Also do a complete thaw/ defrost. You can remove the plastic coverings and ensure all ice is defrosted. Using a hair dryer will speed up thawing/defrosting process.
Nov 06, 2013 | Freezers
How tro restart my digital freezer?
Can you hear the compressor start? If not try the extreme freeze button. Check the condenser is clean and fan working ok.
Jul 24, 2012 | Frigidaire Freezers
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Everything in our freezer is frozen solid except for the ice cream which is soft and mushy, the freezer is only about 3-4 years old and we checked and it is turned up to the coldest setting, any ideas what...
If this is a self defrosting model make sure that you don't have frost build up on the back wall of the freezer causing the air not to circulate like it should. If you do have frost build up other items will eventually start thawing as well. If this is the case you have a defrost problem.
If this is not a self defrosting model then make sure it does not need defrosting.
You normally will notice ice cream being soft before you notice other things thawing.
Also make sure the door is shutting good and you may try putting the ice cream in a different location.
Jul 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on but the rest seemed ok. Today noticed a puddle from thawed meat. Sounds like...
Good day,
Serious problem. Either there is a freon leak or a restriction inside the tubing that carries the refrigerant.
Needs the attention of a pro.
Note. If the unit is under 5 years, leave it alone. It is still under factory warranty. Call for warranty service.
May 12, 2010 | Freezers
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
May 14, 2008 | Kenmore Freezers
Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW Logo
174 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
