Our Whirlpool 6 AWG 751 front loader wahsing machine has stopped mid way through a cycle due to a black out. However when the power came back on the machine did not continue the cycle and will not empty the water out of the drum. Is there a way to reset the machine so that it will empty?
  • 1462 Answers
SOURCE: Machine stuck mid cycle
filter blocked or brawire or similiar in drain pump take off cover at bottom rear. take of hose going to bottom of tub. filter is in that hose you will have water everywhere. one way round that is to lay machine on side - left side down viewed from rear
Posted on Mar 20, 2007
Noggin
  • 944 Answers
SOURCE: whirlpool awg 370 front loader
was this model sold in india? Please ask your friend if you are unsure. I have tried to find a manual in all the other whirlpool sites worldwide also, and every other place i could think of with no luck. Try contacting them on; http://www.whirlpoolindia.com/dealerlocator.aspx Hopefully they may help - if not please ask again :)
Posted on Jul 16, 2007
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    ginko
    • 19396 Answers
    SOURCE: Whirlpool AWG 354: Water flowing can not stop
    Thet happens because either the water level switch/membrane switch is faulty, or because the water inlet valve is defective and stuck on open. See also : It's overfilling
    Posted on Dec 19, 2008
    • 93 Answers
    SOURCE: whirlpool duet washer, inner stainless drum rubs
    This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
    Posted on Dec 28, 2009
    I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
    Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
    Mar 18, 2015 | Whirlpool Washing Machines
    My whirlpool duet front load washing machine stops in mid cycle
    F21 = LONG DRAIN ERROR
    If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
    Press PAUSE/CANCEL two times to clear.
    Procedure:
    1. Check the drain hose and make sure it is not plugged or kinked.
    2. Unplug washer or disconnect power.
    3. Check the electrical connections at the pump and make sure the pump is running.
    4. Check the drain pump filter for foreign objects.
    5. Plug in washer or reconnect power.
    5. If the above does not correct the problem, go to step 7.
    6. Unplug washer or disconnect power.
    7. Replace the pump.
    Alternative Procedure:
    If the machine cannot be forced to its diagnostic mode then:
    1. Disconnect the washer from the power supply and water supply.
    2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
    3. Remove the Molex connector from the water level switch / pressure switch.
    Refer to the picture below.
    4. Reconnect the power supply but not the water supply.
    5. Power the machine. The machine will enter diagnostic mode.
    6. Power off the machine.
    7. Replace the water level switch / pressure switch.
    8. Reconnect the water supply.
    9. Power on the machine it will work without error
    Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Rotating programme unit stops mid cycle, all programmes
    according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
    May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
    Reset whirlpool front loader
    Power shd be on. Right side of control panel, "end of cycle", hold this down for 3 seconds.
    Mar 21, 2009 | Whirlpool Washing Machines
    Dec 19, 2008 | Washing Machines
    Washing machine stops mid cycle and lights start flashing
    Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
    The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
    Hopefully this will solve the problem.
    Plz rate this solution.
    Thanks.
    Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
    Service manual
    Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
    Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    76 people viewed this question
    Top Washing Machines Experts
