Question about Frigidaire Refrigerators
Hello, I have a side-side fridge. Last night it tripped a gfe breaker in the garage. I reset the switch and now the fridge just 'clicks'. thanks -
  • 108 Answers
Your starter to the compressor is defective. Call a tech out it'll cost less than $150.00 and that's if the compressor isn't grounded. If the compressor is grounded will cost about $350-$450 to replace compressor.
Posted on Sep 25, 2011
  • 828 Answers
Sounds like you compressor has failed. If it is out of warranty the repairs are expensive and not recommended. I fit is still under warranty somebody else pays the major portion of the bill.
Posted on May 26, 2008
Need to know where the reset button is on Kohler jacuzzi tub
The only place I'd expect to find a reset button is on the motor itself. That is, unless it's a ground fault problem, in which case it might be on another ground fault outlet somewhere in the house (possibly a bathroom or garage outlet) OR on the breaker - check the breaker box to see if the breaker's tripped or the GFE button needs to be reset.
Aug 02, 2017 | Jacuzzi Home
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
Last night the frigidare AC with breaker in line
if the breaker reset and the display lights are lit its not the cord sorry to say could be compressor or fan motors.
May 06, 2010 | Maytag M7Y12F2A Air Conditioner
Bissell lift off bagless tripped breaker. Cut
if it overheated, there is a automatic switch in or near the motor that resets automatically...if its cooled and wont start back up??? Then check that your outlet has power to it. if not, reset trhe house breaker and if it does, start hitting garage sales for 5 dollar vacuums....
May 02, 2010 | Bissell 3750R Air Conditioner
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
GARAGE FRIDGE STILL TRIPPING THE GFCI ....WHY?
If your frig is plugged directly into a GFCI, you need to remove the GFCI and replace it with a standard plug. No one should have a GFCi behind a refrigerator.
Jan 23, 2008 | Maytag MSD2756G Side by Side Refrigerator
GARAGE FRIDGE DIED...IS IT THE COLD?
No it has no sensor it sounds like the circuit breaker has tripped or the is no power at the plug..try plugging a radio or lamp in to the plug to test
Jan 20, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
May 31, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
85 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
