Question about Office Depot KS-3000 Calculator
I HAVE A Office Depot Brand KS-3000 12-Digit Calculator. IT SHOW THE NUMBER ZERO IN THE SCREEN, BUT IT DOES NOT SHOW OTHER NUMBER WHEN YOU PRESS IT, IT IS FREEZE, SHOWING NUMBER 0
5 Suggested Answers
SOURCE: Office Depot KS-1500
Where is the battery to change.
Posted on Feb 20, 2011
  • 8023 Answers
SOURCE: clear error on office depot calculator ks-1000
Usually, you press the AC (All Clear) button to clear an error.
Posted on Aug 02, 2012
  • 4 Answers
Instructions can be found at:
http://www.officedepot.com/pdf/assemblyinstructions/842413.pdf
Posted on Jan 30, 2015
  • 146 Answers
SOURCE: How do I change the battery in a Office Depot KS-1000 calculator.
Take the back off if there is a little screw unscrew it first then pop it off if there is no screw then carefully pry the sides of the to panels front and back apart...
How do I multiply numbers?
Clear the LCD screen to zero
To multiply numbers, enter the first number by typing the number key pad; press the "X" key and enter the next number; to tabulate those two numbers, press the "=" key
For example, if you want to multiply the two numbers 125 by 425, the expression pressed on the calculator would be 125 X 425 =
Feb 28, 2015 | Canon P23-DHV 12-Digit Two-Color Printing...
Jan 30, 2015 | Office Depot Office Equipment & Supplies
The words FIX DEG appear on the screen and I can't get rid of it. It doesn't calculate properly
DEG says that the angle unit is set to degrees. You can change it to RADians, or GRADs. However much you want to get rid of all of them you will always have one of them. Learn to live with them.
FIX says that the decimal displays will always show a fixed number of decimals. You can decide how many you keep. Apparently your calculator is configured not to show any decimal digits: the number of fixed digits is set to zero. Change it to some other number
There are other display formats : Engineering ENG, and Scientific (SCI)
There is another format (possibly 2) called Norm 1 or Norm 2.
Set you calculator to one of the Normal formats.
Press SHIFT MODE to enter (Setup) and configure.
Advice: Learn to use your calculator. The best way to achieve mastery is to look inside the manual whenever you do not understand something.
Dec 06, 2013 | Casio FX-300 Plus Scientific Calculator...
Clear error on office depot calculator ks-1000
Jul 31, 2012 | Office Depot KS-1000 Calculator
! have a 2001 ford courier that needs a radio code . Ford deler couldnt help and I now have "err" displayed on screen. I have removed battery and found a 4 digit number written on a sticker but...
To remove ERROR , leave SWITCHED ON..UNDISTURBED until it automatically resets itself
Ford Code EntryInstructions Once the unit has been turned on the display will show 'CODE - - - -' Press preset [ 1 ] repeatedly for the first digit Press preset [ 2 ] repeatedly for the second digit Press preset [ 3 ] repeatedly for the third digit Press preset [ 4 ] repeatedly for the third digit To save the code press the [ 5 ] key to accept. The set should now operate. Enjoy your music.
Jan 16, 2011 | Car Audio & Video
Profit Calculator KS1000, how do I change the dead battery? Where is it?
Turn calculator over
Remove two visible Phillip screws
Gently pry up and remove rubber feet on all four corners-remove screws
Button cell battery (original: VINNIC L1131, replacements: Energizer 389/390 or Duracell D390)
Location: upper right hand corner under metal battery clip
To replace battery: gently pry up left tab and slide new battery with + side facing up (writing visible).
Gently push tab back down
Next: Look at circuit board, locate double arrows
Follow directions: "please press "RESET" after replacing battery"
I just touched the metal flow solder plate (small circle with squiggles) above the words "RESET" with a small screwdriver
TA-DA...it works
Nov 17, 2010 | Office Depot KS-1000 Calculator
How do I set tax rate for the ks-1500 calculator? Need help asap
Type the rate in digits, then press the RATE BUTTON and then TAX button, then GT button. IT WILL SET THE NEW RATE and you are done.
Sep 18, 2010 | Office Depot KS-1000 Calculator
HOW I CAN PROGRAM A NEW SALES TAXES 9.75 ON MY KS-1500
First hit TAX+ then 9.75 then SET then again TAX+.
it will now calculate 9.75% tax.
Oct 05, 2009 | Office Depot KS-1000 Calculator
Jul 09, 2008 | Office Depot KS-1000 Calculator
Office Depot KS-3000 Calculator Logo
142 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
