Question about Sport & Outdoor - Others
I have a model 237 empire lantern,it suposidly burns keracein and i read that you have to preheat it, how do i do that.
How to take apart a model 237 lantern. i removed the nut on top but the handle passes through the top into the sides and i cannot get it off. I don't want to break it
Tough without pictures but this may be a model that has a spring base the lens is on. Try pushing down. If you post a picture I am sure I can help you out.
Apr 20, 2014 | Coleman 10' X 10' Sundome Tent 9160K101
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
EMPIRE MANUAL DV2353SG
I believe all the Empire manuals are there to download or read at their website: EmpireComfort.com.
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
I cant get any petrol to pump into the mantles
If the petrol doesn't come through first check that you have enough in the tank. If the tank is not full enough it won't come through. If it still fails to come through it's likely that the generator is blocked. This is the tube which the mantle sits on and it has a very narrow opening to force the petrol to convert to vapour when it's warm. Try heating it for a while and it may clear it. Otherwise you'll need to buy a new generator.
Note: while the dual fuel lanterns can burn petrol you should be aware that it gives off poisonous fumes, like cars did before they had catalytic converters. The lantern should not be used indoors with petrol. They are safe with coleman fuel. If you live in the USA, Coleman fuel is cheap but if you're in Europe it's much too expensive. Rather than buying a new generator, if you live in Europe, you could buy a parafin burning lantern like the Petromax 500 available from http://www.pelam.de/index.php?cPath=28_31&language=en&gclid=CIOe46DQnqYCFQkf4QodQxz2Zg
and other sites, or you can pick up second hand Optimus lanterns on Ebay. Both burn parafin, though they need to be primed, and provide at least as much light as the Coleman.
Jan 03, 2011 | Coleman Northstar Dual Fuel Lantern
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Sport & Outdoor - Others Logo
29 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
