Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
When I open My Computer and look at the properties of My Book, it says that there are still 330GB remaining, but when I try to copy ANY file, even as small as a blank word document, I'm told that there is not enough space remaining to copy anything. I've tried running the disk error check, defragmenter, and disk cleanup and I still get the same thing. Is there a way to get my 330GB's back? Or are they somehow lost forever?
    Guru:
  • 124 Answers
Maybe the disk quota on your my book is enabled. To check just right click your "my book" then click on properties. Then go to the :quota" tab and disable or remove the check on "enable quota management"
Posted on Oct 07, 2010
Unable to recover xp address book
Try:
The Recovery ToolBox for Address Book tool makes it possible to recover contact information from the Windows Address Book where data used by the mail clients Microsoft Outlook and Outlook Express (*.wab files) is stored.
For more information: https://addressbook.recoverytoolbox.com/
Jan 08, 2015 | Microsoft Outlook Express
It says my hard drive has 330gb of space, but when i try to copy a 5GB file onto it it says there is insufficient space. please help
have you re formated your porta drive lately ????
may be it''s time to get the ontrack disk mager to protect the boot sector from worms and trojans
asi have had the same problem in the past and on track did the trick for me
wd should have the dm1.zip file on there websight under suport
Dec 07, 2009 | Western Digital My Book Essential Edition...
I transfered some photos from a CD to my computer and am trying to edit them with my ArcSoft 6.0 program. I can crop them, but when i try to save, it says, "Read only file." and asks me to rename it. What...
When files are placed on a CD they are automatically changed in their properties to Read Only files. When those files are copied back to your hard drive they retain that Read Only property. All you have to do is bring up the file Property window and clear the check mark by the Read Only box. If you are using Windows, open Windows Explorer and browse to the files. Right click the files and choose Properties. The General tab should be the first tab that will open up At the bottom of that tab you will see a section called Attributes. One of those Attributes should be Read Only, and there should be a check in the box beside it. Just click on it to make the check mark go away and that should solve the problem.
Sep 18, 2009 | Arcsoft PhotoImpression® 6 Full Version...
External hard drive use 101!
When you plug the drive into your computer it should come up as a new drive letter (drive E: for example). To back up files right click onto the files that you want to backup and left click onto copy then open the drive letter for the my book and right click and left click onto paste. this should copy any files that you would like to back up to the I book to restore simply reverse the process.
Sep 11, 2009 | Western Digital My Book Essential Edition...
Deleting a file from desktop .
  • Restart the computer and try to delete it.
  • get in to safe mode and try delete it.
  • Disable all the sevices and try to delete it.
  • try to delete it from command prompt.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Feb 28, 2009 | Microsoft Windows Vista Ultimate Edition
Transfering address book and Favorite Center fom one computer - -
Your Favorites are stored in Cocuments ans Settings folder under your name and in the Favorites folder.
Eg. C:\Documents and Sttings\"your name"\Favorites
Copy the Favorites folder to a USB memory stick and then copy it to your 2nd computer in the C:\Documents and Sttings\"your name" folder - exactly as per your Toshiba.
To transfer your e-mail address book from one computer -
1. Open Outlook on your Toshiba, then click on File, then Export, then Address Book - save this file (remember the file name and the location where you saved this file.
2. Copy this file to a USB memory stick.
3. Open Outlook on the Gateway computer.
4. Then click in File, then Import, then Address Book, then to the USB memory stick (could be your E: drive) where the exported address book file is located.
A copy of the address book is now in your Gatway computer.
Jan 17, 2009 | Computers & Internet
My Book 1Tb will not let me copy movies on to it.
To transfer files larger than 4GB to the drive, the harddrive must have an NTFS File system. Unfortunately, the FAT32 File system is not capable of handling a single file larger than 4GB (to be exact, one byte less than 4GB). Follow the steps below to format the harddrive with an NTFS File system:
Warning, all data on the harddrive will be lost! Please backup the data on the harddrive before proceeding.
  1. Locate My Computer (Computer in Vista). Right-click on the harddrive and select Format.
  2. Select NTFS from the File system drop-down list.
  3. Select Quick Format as the Format option and click Start.
  4. Note: If NTFS is not an available option, close the Format window and follow steps 4-9.
  5. Right-click My Computer (Computer in Vista) and select Properties.
  6. Select the Hardware tab and click Device Manager.
  7. Expand Disk drives and right-click on the harddrive. Select Properties.
  8. Click on the Policies tab and select "Optimize for performance.”
  9. Click OK.
  10. Repeat steps 1-3.
Nov 28, 2008 | Western Digital My Book Essential Edition...
Saying I can't copy 9gb file due to lack of free space, 433bg still showing free
that might be due to the drive being formatted as Fat32 which has a file size limitation of 4 Gig..open up my computer, and look at the properties of that drive..right click..and that might help you
Oct 15, 2008 | Western Digital 500GB My Book World...
My Book Premium
Suppose you're using MS Windows... Click right button on (I) drive then check out "Properties" of your drive. In "General" tab you should see "Used space:" and "Free space:" If in "Used space:" is something like "24 KB" then it looks like you lost your files :( Otherwise somehow may happen that your files became "hidden" or "system" files. In "Control Panel" open "Folder Options" in tab "View" check/uncheck properties of "Hidden files and folders" and "Hide protected operating system files(Recommended)" to see what is in your (I) drive. Anyway may be helpful some program which can recover accidentally deleted files. Try to google "recover files" for such program.
Sep 18, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
91 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
