Question about Samsung DynaFlat TX-P3064W 30" TV
My tv cant turn on
Hi am ben, my sumsang tv cant turn on, was switched off and on turning it on, never worked. later i realized that when it powerd it caused the cct breaker to trip but the fuse never blowed.i replaced the power transitor C5299 &it stopped triping the cct breaker but still cannot turn on.Advice (my Tv is a 29" CRT colored TV)my email adress. - bemuus@yahoo.com
Thanks
  • keku May 27, 2008
    Thanks i'll check on that.
    thanks again for ur availability.
    Scholar:
  • 131 Answers
Make sure the c5299 s not shorted again. and if it is not i suspect your flyback transformer is bad . check for cold solder joints on voltage regulator and board.
1 flyback transformer
2 voltage reulators
places to get parts
1 www.partstore.com
2 www.samsung .com
Give Them the model number they can cross it to part
GOOD LUCK DOCTOR VIDEO
becareful it is highvoltage
Posted on May 26, 2008
I have aTLX-4244B turns on blue 2sec.goes BLK. cant find switch buzz when turned on
To find the solution for this tv, read my fixya response,
it worked for me, and it should for you
just follow step by step and get your tools and lamp ready
let me know later...
thanks
Mar 08, 2013 | Polaroid FLM-3225 32 in. LCD Television
When I hit the On switch to my TV the Green light turns on but it takes up to 5 minutes before the TV realizes there is a signal. After 5 min the it comes on just fine. I've tried turning on the tv to...
hello my is rico and i work on tvs sometimes. the problem in your tv your power supply caps, some of them gone bad, need to replace them, for the tv to start working back to normal again, because later on the tv will not come onb anymore. if need more help with your tv please feel free to call at anytime. 602-810-7149 i live in mesa az
Dec 30, 2010 | LG 42LC2D 42 in. LCD HDTV
Sierra 1500 wont turn over 350. locked up???
Have the battery tested for a dead cell. It may test at 12 volts but that doesn't mean there isn't a dead cell. Also, if the motor has good compression you probably shouldn't be able to turn it over by hand at the fly wheel. Maybe an old school motor with V belt, but not a newer motor with all those accessories attached to the front.
Mar 14, 2010 | GMC Sierra 1500 Cars & Trucks
Hi I cant get signal from my laptop to my LCD TV, don't know how to set it up. Tks
Usually you need to connect your LCD TV to the laptop and then restart your laptop and in the meantime keep the TV on. It will recognize it automatically.
if this didn't work you need to go to the graphic card setting by Righ-Click on your desktop background > Properties > Settings
and make the right setup.
Ben
Jan 09, 2010 | HP Pavilion dv6000z Notebook
I have a sumsang tv 40 inch but the problem is the red light flashes on and off i don't know what the problem is it wont turn on
Check the fuse in the plug.
If it is not the fuse, check the cable is not damaged.
If not the cable, it may be the TV itself.
Dec 05, 2009 | Samsung Televison & Video
Cant get it to go back to av
You have to reset the display setting and this is how you do it. make sure ther is no disc in the system, turn off ps3 in the back (main power switch), turn that switch back on and you should have a red power light, hold the power button, you will hear a beep right away and the a 2nd beep a few seconds later and then let go of the button. The light should be green, if it still does not work try the steps 1-2 more times. If this does not work, you will need to cal 1-800-345-7669 to get your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
I have 2006 dodge charger and when i turn the key to start the car, it takes 3 to 5 sec and then the car when turn on... everything turns on when i turn the key and then 3 to 5 sec later the moter turns...
Hi you will have a problem with the transponder signal retreiver. this is the component that tells the computer that the correct key is in the ignition. you will have to take it to a dealer to get it checked. Cheers Ben
Aug 08, 2009 | 2006 Dodge Charger
White screen, no sound
Are you still accessing menu? Can you connect your PC to TV and see a signal?
Jan 25, 2018 | RCA F19420 19" TV
How to turn off message and missed call warning tone
Hi there Guru7487, go to settings; Sounds; And its somewhere in there, mine doesn't work so i cant give you a detailed plan..
Hope it works
Ben
Oct 14, 2007 | Motorola Mobility L6 Cellular Phone
Samsung DynaFlat TX-P3064W 30" TV Logo
153 people viewed this question
Jerry Greenberg
Jerry Greenberg
