Question about Whirlpool Dryers
The inside is not rotating - Whirlpool Dryers
    Problem Solver:
  • 6 Answers
When yo start the dryer do you hear the sound of a motor start and run? If so it is possible that the belt has come off that turns the drum. If the belt is on then it is likely an electrical problem and for some reason the dryer is not starting the motor. In that case I would check the safety switch that is pressed when the door closes.
Posted on Oct 02, 2010
  • bradley99 Oct 18, 2010
    If that doesn't fix it, what is next?
HI, This is IRFAN, i have Canon IR 3300 copier machine i got a error e007 000, i know the that is fuser film rotation error, but, i had remove the Fuser unit (FG6-6040-000) from the machine and manually...
If you confirm about film's inside lubrication then cheak out for gear inside fixing drive assembly . open front door , open inner cover then open the drive assembly from the left and cheak the gears.
Aug 25, 2017 | Canon Ir 3300i 3300g 2800i 2800g 2800 2200...
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
I have a philips HS 8040 MOISTURIZING SHAVING SYSTEM FOR MEN THE PROBLEM IS THE GLIDE RINGS DO NOT ROTATE
The glide rings are not supposed to rotate. Only the blades on the inside are supposed to rotate.
Aug 21, 2011 | Philips Health & Beauty
Refrigerator Whirlpool model GD25BFCHB00 not working - no power to compressor. Note this is an electronic controled model. How can I determine what part is required?
May be timer problem. Rotate the timer manually (Back side of the refrigerator / bottom Near the compressor / inside the freezer) Refer diagram. Rotate then working... Problem Timer / Heater protector .. replace (inside of the freezer)
Mar 22, 2011 | Whirlpool Refrigerators
The top bar on the inside that holds the racks has stopped spinning during bake.
The top bar, referred to as the "carrier" will only rotate when you start your bake cycle. If there is an issue with the rotation you should hear a steady buzzer about once every second. If you are hearing the buzzer that means the rack alignment switch isn't closing momentarily during rotation like it should be. This could be a result of a number of things, such as a bad rack switch, mis-adjusted rack switch, burned or broken wire on rack switch, bad rotation motor, rotation motor chain or sprockets fell off or are loose, or the shaft switch bar is loose (unlikely).
If you are NOT hearing the beeping then the carrier inside the oven itself could have some loose set screws and the shaft could be spinning freely inside the carrier.
Look on top of the oven and you will see a rectangular shield covering the lift and rotation assembly, remove these covers and verify if the shaft is spinning and hitting the little switch mounted near the top of the shaft.
Mar 01, 2011 | Baxter BXA2G Stainless Steel Gas Single...
The Celestron Nexstar 4SE makes a weird cracking noise when you press the left or right arrows on the controller. I tried taking it off of the tripod, and it still will not rotate left or right, even if...
Is the AZimuth clutch locked down? Then either a gear is broken inside or the worm gear inside has slipped and is not engaing. You can return these to Celestron for repair, here:
http://www.celestron.com/c3/page.php?PageID=37
Dec 26, 2010 | Celestron NexStar 4 SE Telescope
The bagless rotor does not rotate/sweeper does not rotate
There is no rotor inside the clear container that turns on a DC07. The stuff spins due to the shape of the airflow. Perhaps your cyclones are completely clogged. you can clean them yourself. see this video http://www.youtube.com/watch?v=2OO3ugkyzxk
Jul 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Front cog does not rotate when pedaled
You will have to remove the rear wheel and take it in to a bicycle shop and have the rear cog replaced. The freewheel part inside it has likely broken and will only rotate in both directions. It should rotate to back pedal and then catch as you pedal forward.
Apr 08, 2009 | Freestyle Cycling
Help inside tray will not rotate
check rotated plate and connecting surface ok.
Nov 12, 2007 | Emerson Black Microwave Oven
Dryers Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
