Question about Windchaser PACR10 Portable Air Conditioner
It gets cool for like 10min den it shuts down
Windchaser.pacr10 will run five or ten minunts and doesnot drip any water water using a four inch homemade duct on it.
Posted on Jul 27, 2011
  • 1,711 Answers
    Sergeant:
  • 191 Answers
Open the unit and clean the clogged evaporator with a shop vac. (inadequate venthilation)
Posted on Jul 29, 2013
  • 3 Answers
The manual says that the unit will shut off due to one of the following: exhaust hose too long or kinked, unit too close to wall or object, inadequete ventalarion, timer off function is activated, or room temp is not between 61 and 90deg!
Posted on May 12, 2012
How long after the chime and cool down period should the dryer cut off.
most timer havea5min are 10min cool down cycle u can time the cycle
Sep 24, 2015 | Frigidaire FAQE7001LW Dryer
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Fans running constantly hp laserjet 8150
my guess, its packed in lent and needs cleaning>?
but i can not see it, so....
try the real form at HP>?
the 10min rule to me sounds bad rumors.or just near usless estimate. is this printer in and office setting or a hot garage?
what is the ambient temperature. there.
fans in most cases all are temperatures sensors, tell it , its too hot.
  1. so it is too hot
  2. or, the sensor bad
  3. or the controls bad
  4. or programmed wrong.
real forum. try it?
https://h30434.www3.hp.com/
May 15, 2017 | HP Computers & Internet
ONLY RUNS FOR 10MIN THEN PANEL FLASHES AND WASHER STOPS
Hello there:
there are generally 4 things that would make this happen
Dishwasher cycle does not complete
best regards Michael
Dec 30, 2009 | Dishwashers
Laptop would start up but shut down immediately and the battery w
How long does it stay on for? I had a similar problem. Mine would stay on for 10min then shut down. It ended up being an excessive build-up of dust around the cooling fan. If your problem is similar its worth taking a look at. Good luck, Todd
Dec 22, 2009 | Toshiba Satellite A25-S207 Notebook
Samsung tv is shutting off all the time.
Do you have enough air flow to cool it?
It may be overheating....add a fan blowing into it and see if that keeps it on.If it does put a strong small computer fan in somewhere to keep it cool.
Aug 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Refrigerator not cooling - shuts off every 5-10min
You need a new start relay. it is attached directly on the compressor where the wires go in. Take it off and shake it if a box of matches....
May 10, 2009 | Refrigerators
I just upgraded my pc by MSI G31M3 but turns off in ~10min
Change the SMPS to a higher wattage rating. Your old one might not be able to supply the required wattage hence it heats up and automatically the PC shuts down to prevent any further damage. A extra cooling fan at the back would help too, i.e. after installing the new SMPS of 450-500 Watts.......sodeep
Mar 16, 2009 | Intel Motherboard
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Logitech S520 mouse and keyboard Screensaver and power shut down
Not a solution but it may bring some light to the problem,
There is some program calling windows every 10min or so... that's why your screen saver gets interrupted. You might need to check which program is it. Or guess it out.
Hope it helps, if you have more doubts feel free to ask.
Jan 03, 2009 | Logitech S520 Mouse
Windchaser PACR10 Portable Air Conditioner Logo
515 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
