Question about LG WM-2277HW Front Load Washer
My LG WD 1238C makes a very loud grinding and clanking noise on spin cycle, tried cleaning drum and filter as suggested in manual trouble shooting guide but didn't solve the problem, how do i fix this. Thanks
  • 62 Answers
SOURCE: LG wft7014pp wont drain rinse nor spin
do you have a drip-dry function...as this cancels the spin cycle unless you select it yourself
Posted on Jan 03, 2008
SOURCE: LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Posted on Mar 06, 2008
SOURCE: Noise on spin mode fast loud clanking like something in drum
Wow, we're having a similar problem vibrating like crazy...just online to try and figure it out..
Posted on Dec 29, 2008
DRACO A5OG
  • 22 Answers
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Posted on Dec 31, 2008
  • 7 Answers
SOURCE: mah3000 aww making extremely loud, clanking, grinding during spin
Gotta admit tonytools albeit not cheap has the best easiest tool to do that rough difficult repair.
Posted on Feb 18, 2009
What is wrong with my washing machine?
remove the agitator and look for coins , buttons and other objects jamming the spin , agitator and drum
Dec 12, 2015 | Electrolux Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Mah3000 aww making extremely loud, clanking, grinding during spin
Jan 01, 2009 | Maytag Neptune Washer
Everything works great -until the spin cycle - loud noise
Have you checked to make sure all three shocks under the tub are ok?
Dec 18, 2008 | LG WM-2277HW Front Load Washer
LG Washing machine
its hard to know without hearing it,is there somthing stuck between the drums try taking the belt off and turning the drum by hand.sorry i cant be of more help
Mar 04, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
141 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
