Question about Amana ARB1905C Bottom Freezer Refrigerator
Freezer not cooling properly and iceing over - Amana ARB1905C Bottom Freezer Refrigerator
    President:
  • 834 Answers
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism.
Here are some images that should be similar to your situation to help assist you and the principal is the same with either over-under or side by side refrigerstors, and let me know if you require any further assistance.
830f9c2.jpgfreezer not cooling properly and iceing over - 7202c88.jpgbr /> 0436105.jpg
f98e89afreezer not cooling properly and iceing over - 32618eb.jpg=
Posted on Oct 02, 2010
My water in my ice maker is warm and there is a smell like a backalite coming from freezer
Its not cooling properly,the issue is weak or dirty compressor section and related parts.Get the refrigerator serviced completely and see if its help.Otherwise compressor needs to be replaced.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Where is the control for the freezer compartment
On the inner side of the freezer compartment.Its for cool,and winter mode,fast cooling mode.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 24, 2012 | Refrigerators
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
Jcb 2059 Jen air fridge not cooling freezer o.k.
Its a defrost issue.The freezer works,then cooling starts and then its time to defrost.But in defrost the unit is not working.It can be faulty defrost assembly parts.Or the problem is with defrost timer at the lower back side of refrigerator.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Freezer fan not running
It can be faulty fan motor or blown compressor capacitor.
These will help.
Thanks,.
The freezer rale broke
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 22, 2012 | Amana ABB1927DE Bottom Freezer...
Deawoo fridge freezer FDF-358 freezer is cold, fridge is not getting cold
The freezer section is working,but fridge is not because defrost door is blocked.Its a defrost cycle issue.
These will help.
Thanks,.
Why is green light flashing
Its indication of overfreezed fridge or freezer unit.Or any door not getting closed properly.
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Amana ARB1905C Bottom Freezer Refrigerator Logo
146 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
