Question about RIM 2.5mm Headset fits most Cell Phone models Headset
I currently have my headset hooked up to my Motorola Droid. Not sure if it is just not compatible, but it was working for about 5 weeks. For whatever reason, when I have my headset connected to my phone, I can hear the recipient, but they cannot hear me. It seems that there is some mute button that got pressed, but I cannot figure out where. Is this a feature that needs to be addressed on my phone. I contacted Droid and they were no help and suggested I contact the manufacturer.
    Master:
  • RIM Master
  • 541 Answers
It is the headset. I google rim and come up with many, many types. There may be a slide on the headset, usually inline that needs to be moved.
Posted on May 31, 2017
  • 52 Answers
SOURCE: address book help / won't open
Reset the phone by removing the battery for 10 seconds. That should release the application freeze.
Posted on May 22, 2008
SOURCE: Can not open my Address book - everything else works!
A co-worker suggested I simply remove the battery for a few seconds and then restart. That's all it took to solve the problem!
Posted on Mar 19, 2009
SOURCE: Unable to view my Address book
This is typically caused by a filter being applied in the address book. Open you address book, press the BB menu button, and select filter. Once you are in the filter options, make sure that all check boxes are unchecked, then exit back out.
This may not be the cause of everyone's issue, but it may be a solution to some of the problems.
Another thing to check is if the contact are actually in the "Sim Phone Book" opposed to the regular address book. Open your address book, press the BB menu key, and select "Sim Phone Book". After doing this, you may see all of your contact in there and you should be able to copy the contacts to the BB.
Posted on Apr 16, 2009
SOURCE: Blackberry Pearl Issues- Does anyone have these issues?
U are a ********
Posted on May 27, 2009
  • 65 Answers
SOURCE: Blackberry storm phone not compatible with MAC computer.
There is a download for pocket mac on Blackberries website. this should work. After installing the initial one, there is a patch The patch address is listed below.
https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=34198D7C90441E04CC12D150AE13BDF7
if you are still experiencing issues, please contact Verizon Wireless support while using a different phone than your storm. The support team should be able to walk you through getting your equipment to sync. The storm should be compatible with a Mac.
Thanks.
Posted on Jul 31, 2009
Can you hook up a Motorola Droid RAZR HD on a pre paid account?
TRY WWW.FREEDOMPOP.COM I HAVE USED IT FOR OVER A YEAR NOW.
Jan 29, 2015 | Motorola Mobility Droid RAZR HD
I have a droid x and i cant listen to voice messages or music thru my blue tooth... any suggestions.
Check your bluetooth and make sure that it is capable of playing music through the headset. I had a Motorola Bluetooth headset that was unable to play music through it, but I later then upgraded to a Plantronics headset, and this played music just fine.
http://www.plantronics.com/us/product/voyager-pro
As for not being able to hear voice messages through your bluetooth headset, make sure that the volumes are up on both the device and the headset, and try deleting the paired device and re-pairing it!
Feb 25, 2011 | Motorola Mobility Droid X
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I have the droid backflip and my boss has the first droid from verizon, neither can find the bluetooth headphones (motorokr s9 black & red) how can i pair the headset to my phone if i cant find it
Make sure you put the headset into discoverable or pairing mode, there should be specific instructions that came with your head set to do this, then use the droid or the backflip to scan for the devices and it should find them.
Oct 18, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
Is it compatible with the motorola droid
According to http://www.jabra.com/Sites/Jabra/AP-EN/Headsets/Pages/JabraBT350.aspx , yes, it is compatible.
Apr 27, 2010 | Jabra BT350 Bluetooth Headset Headset
Can't pair my VBT2050 with motorola Droid
BT2050 must be off.
Push power button and round top button on BT2050 ear piece at same time until white light stays on. Both must be held down together.
Once white light is continuosly on (not blinking) then put droid in "Scan for device " mode.
Pairing should then take place
Apr 05, 2010 | Jabra Bluetooth Headset with Adjustable...
I have s9 headset and anew droid ,lost my manual
http://direct.motorola.com/ens/s9/S9_User_Guide.pdf
here is the user guide
and how to connect the devide is on page 15
Mar 04, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
How do I sync my motorola H710 bluetooth with my Motorola Droid?
Here's the instruction manual for the H710:
Motorola H710 download instruction manual .pdf 2MB
You'll have to check your owners manual for your Droid, but it's probably under Settings > Connections > Bluetooth (Turn on) > Discover (Pairing code 0000)
Feb 04, 2010 | Motorola Mobility H710 Bluetooth Headset
I have a new droid by motorola and an old h500 bluetooth headset. It still pairs beautifully with my old blackberry, but won't pair with the droid. HMMM? Any tricks? What am i doing wrong?
You need to put your H500 into "pairing mode" by pressing the call button until the light turns steady blue, instead of blinking. Your droid will then see it when you are in the Bluetooth Settings screen under Networks & Wireless. I just did this myself last night and it worked fine. Be forewarned, however, that you cannot voice-dial with your bluetooth - only answer calls. There are several forums out there that are bashing Motorola & Google for not having this basic functionality.
Dec 26, 2009 | Motorola Mobility H500 Wireless Headset
RIM 2.5mm Headset fits most Cell Phone models Headset Logo
29 people viewed this question
Top RIM Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a RIM Radio Communication Expert? Answer questions, earn points and help others
