Question about Panasonic DP-2010E All-In-One Laser Printer
My Panasonic do-2010e copier printer has a code u20 close adf cover. How do.I fix
2 Suggested Answers
  • 224 Answers
SOURCE: adf cover u20 error
the tray that you put you originals on, lift it up towards you left. under that tray is another door sort of hidden away, that needs to be closed
Posted on Apr 08, 2010
ADF cover is open
Sounds like a sensor is broken. Whatever caused the initial errors was not fixed and continued use has permanently broken the product.
Mar 16, 2015 | Brother International Inkjet Multifunction...
The fax/ printer says close adf cover then press stop, the cover is closed down properly and there is no paper jams everything is closed properly ?? what do i do to fix it? thanks!!
the ADF cover is the automatic document feed. make sure the cover above that tray is closed tightly. maybe try opening it and reclosing it. sometime the sensors get jammed up.
Nov 08, 2012 | Office Equipment & Supplies
Analyser open U20
U20 code indicates that the document feeder on top of the machine is not closed .Ensure that cable at rear of doc feeder is secure.Otherwise it may be a broken/faulty sensor.
Dec 11, 2011 | Panasonic DP-8016P Copier
Panasonic DP 2500 photocopy machine from you a few months ago. I cleared a few paper jams and have not had a problem until now. The message on the machine says to ?close the ADF cover?. I do not know what...
the top cover that opens to the left normally has a small piece of plastic that slots into a sensor toward the back of the adf. this small piece has broken off so the machine thinks the adf is open. an engineer would need to replace the door for you.
Jul 22, 2010 | Panasonic Workio DP-2500E Copier
CLOSE ADF WHEN A SHEET IS PUT INTO IT
There is a switch under the ADF check and make sure that switch is engaged when ADF is closed
Switch is located in the Middle of ADF right above the ADF Sensor on the machine platen glass
Apr 09, 2010 | Panasonic FP-D250F Copier
Adf cover u20 error Cover is closed.
Apr 02, 2010 | Panasonic WORKiO DP-C262 Printer
Dp-2010e code e04-01
E 4-01 is a fuser error that only can be reset in service mode F9 reset fuser
Jun 26, 2009 | Panasonic Office Equipment & Supplies
Error U20
U20 indicates the ADF cover is open, look to see if something is preventing the ADF cover from closing, like small piece of paper or something out of place.
Apr 27, 2009 | Panasonic Workio DP-2500E Copier
My Panasonic DP2500 copier
remove paper jam light stuck on, but there is no paper jam
Apr 17, 2008 | Panasonic Workio DP-2500E Copier
Panasonic DP-2010E All-In-One Laser Printer Logo
43 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
