Question about Haicom GPS
HAICOM HI-408BT Bluetooth receiver will not acquire a satellite or connect via Bluetooth. Yellow satellite and blue Bluetooth indicator lights a flashing constantly.
  • jagnemark Oct 02, 2010
    Tim:
    No reset button on this unit.
    President:
  • 2,777 Answers
That is a major malfunction of the unit. I believe this unit has a reset button on it, or can be reset from a menu. Try that, does it at least acquire satellites after that? If not there is something major going on.
Let me know, Tim
Posted on Oct 02, 2010
  • Tim Grayson
    Tim Grayson Oct 02, 2010
    Ah yes, you are correct, I pulled it up here and there is no reset button. Yikes that is very very bad news. The fact alone that it will no acquire satellites means the internal receiver has failed on this unit. It is the same management module that controls the blue tooth as well, so it makes sense that that went out at the same time. Unfortunately, unless it's new enough to be under warranty, you will need to replace this unit :(.
    Tim
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
HI-303III
is it detecting.when you connect it to the computer.
Aug 25, 2008 | Haicom HI303MMF-Blue GPS Receiver
Tip
Colour full BlackBerry ..If you are a Blackberry user.You must read this
In BlackBerry LED indicator blinks in different colors to deliver different notifications to the user:
Blinking RED: The LED indicator blinks red whenever you have incoming or waiting communication messages on your phone - new email, new call or missed
call,
Blinking GREEN: this is Coverage Indicator light. This lets you know you are connected to a network.
Blinking BLUE:If your phone is connected to a Bluetooth device, such as a Bluetooth headset it blinks blue.
Blinking YELLOW: A blinking yellow light means it is time to charge your BlackBerry
on Dec 15, 2009 | Cell Phones
I need driver Haicom HI-406BT-C GPS Receiver
You can download it from:
http://www.haicom.com.tw/support.aspx
Mar 18, 2011 | Haicom HI-406BT-C GPS Receiver
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Connection problem
The easiest solution is to acquire a program called blue soleil which is available as a trial program.
The website for download is : http://www.bluesoleil.com/download/.
The software is very user-friendly and should sort out your problem.
Regards,
Graemevm
Apr 19, 2009 | Computers & Internet
My Garmin c330 has difficulty acquiring satellites in my new 2009 Camry XLE. Does it have something to do with Bluetooth? Does it interfere? Ever since we bought the 2009 Camry XLE in June, the Street...
The C330 does not have bluetooth capability. Regardless, this has nothing to do with the unit's ability to acquire satellites. Nor should the type of vehicle you purchased, unless the unit is unable to receive due to some feature, like something in the windshield, which is preventing the unit from receiving a proper signal. Does the unit work outside the vehicle?
Aug 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Fj-800 bluetooth headset
I have such a pair and they work great. As soon as I turn them on, they connect to my phone and my phone (Nokia N95) unpauses the music - instant bliss.
Mar 29, 2008 | Audio Players & Recorders
GPS Logo
354 people viewed this question
Top Haicom GPS Experts
Are you a Haicom GPS Expert? Answer questions, earn points and help others
