Question about Lite On LH-18A1P DVD±RW Dual Layer Burner
Why does eject dvd not work - Lite On LH-18A1P DVD±RW Dual Layer Burner
  • Lite On Master
  • 27,725 Answers
Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
good luck
Posted on Oct 02, 2010
HP Pavilion DVD player won't eject but plays the dvd
Try goint to My Computer and right click on the DVD player. If the eject works, the external eject switch is not working. If not, the mechanism is misaligned or damaged.
Oct 15, 2014 | HP Pavilion Computers & Internet
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Cannot eject DVD drive
on the dvd drive below the tray normally on the right hand side there is a little hole get a pin or something to fit the hole and insert it into it while doing this the disk tray should manually open this should allow you to get your disk out :)
Jan 19, 2012 | Gateway Computers & Internet
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Door will not open
make sure the drive is not reading a disk, because if its spinning it can break when you do this process.
look for a hole in the front of the drive, get a paper clip and stick it in there all the way, the tray will now eject or if its a slot loading drive the cd will eject
Sep 06, 2010 | Computers & Internet
IMac5,1 DVD-R won't eject.
restart mac and hold down the mouse after you hear the startup noise
if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
Hope this helps.
Oct 30, 2009 | Computers & Internet
Go Video DVD will not eject
this suggestion made on this forum worked great for me.
I don't care if it does sound silly.. smack the unit smartly over the eject tray when you press the eject button.
Dec 23, 2008 | GoVideo Go Video DVD/VCR Combo
Dvd will not eject manually or with remote tried unplugging and restarting it didn't help
It probably wasn't the best solution but it worked. I tried to jimmy open and pull out the dvd tray. When that didn't work I tried pulling the dvd out with needle nose pliers, but it did not budge. Finally I hit the eject button one last time and it worked. I hit the eject button a couple of more times and it did work. I did ruin the dvd, and haven't had a chance to play another dvd to see if it is working properly.
Nov 10, 2008 | GoVideo Go Video DVD/VCR Combo
Dvd & vcr DV2140
TRY UNPLUGGING THE UNIT FOR A FEW MINUTES.SOMTIMES THIS WORKS.
Nov 01, 2008 | GoVideo Go Video DVD/VCR Combo
DVD Stuck in Player
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
Mar 16, 2008 | Sanyo DWM-390 DVD Player
Lite On LH-18A1P DVD±RW Dual Layer Burner Logo
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
