Question about 321studios DVD X Show for PC
I have just upgraded to Windows 7 from XP and i am trying to load all my software and when i try to put on DVDX Copy I get the following message. Cannot create file "C:\Windows\system32\IOSUBSYS\PCOUFFIN.VXD". and when i try to backup on Shrink i get Failed to read file "D:\" Both of these used to work perfectly for me.
  • 5 more comments
  • parker_coote Oct 02, 2010
    I upgraded to Windows 7 home premium.
    Yes i am useing disks to install X copy & Shrink. How do i fix these errors?
    Well there is a problam obviously, I know it cannot read the file as that is what the error is saying, and i guess i just wasted $15 for you to tell me what i already knew.
    The cd's are fine and i have used them on this pc and others.
    Didnt work
    X copy has now installed properly thankyou.
    I havnt checked shrink yet. Im in the process of copying a dvd in X copy to see if it has worked
    NO didnt work
    It is the first time with windows 7.
    It went beserk with all sorts of errors during the writing fase, im trying it again now.
    Error message during writing process - DVD X copy XPRESS could not load its resources properly, please reinstall.
    Also had another one - Access violation at address 0040C260 in module 'XPress.exe' read of address 00000018.
    Do you know what this means
    Genius:
  • 1,035 Answers
Hi. Did you mean upgrade or downgrade? XP is older version than windows 7. Error you are getting means that the system cannot find the path specified. Are you installing the program using the the installer disk?
Posted on Oct 02, 2010
  • 4 more comments
  • Angelito Rabago
    Angelito Rabago Oct 02, 2010
    If you are using the disk in installing the program then there should be no problem with that. Make sure that this program is compatible with windows 7. If you will check the error message " cannot create file C:\Windows\system32\IOSUBSYS\PCOUFFIN.VXD. Windows is trying to install this program but it cannot read a particular file from your CD that is why it cant create a directory to your C drive. have you tried using the CD with other computers?
  • Angelito Rabago
    No you are not wasting you money here at fixya. There is always a solution to the problem. Create a new folder to your desktop and copy the whole disk inside that folder. If you have second disk of this installer then copy it also insdethe folder. Look for a file named setup.exe and run that file. Let us se if installation will push through.
  • Angelito Rabago
    are you getting the same error mesage? Is this the first time you install this program wo a windows 7 platform?
  • Angelito Rabago
    Ok.
  • Angelito Rabago
    What is the error message?
  • Angelito Rabago
    that error is particularly for the program tha you are trying to run. This means that the program crashes upon initializing its process. Even if you google this error you cannot pull up any information of this error. another option is to try to download the same program over the internet and see if it is doing the same thing. My initial finding is there could be a glitched somewhere in the installation. You may try uninstalling and reinstalling the program.
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
We just upgraded to Windows 7 and we cant get our old invoice program to load. Its Proventure Invoices & Estimates version 1.0.0B . Can you help us?
Your accounting software may not be compatible with Windows 7. Check the manufacturer's website to see if it is or not.
You can also try the Windows 7 compatibility fix.
To do this, follow Microsoft's suggestions here.
Sep 16, 2010 | Avanquest ProVenture Invoices...
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
Since upgrade to itunes 9.0.3 used with explorer 7 and windows xp, receive error message 1202 on itunes store when click on any links to subscribe to podcasts or on link to to report a concern
Can try to right click on "redeem" on the Itunes home page. When it gives you a choice to open or copy the link, select "copy this link". Paste it into a new Internet Explorer window and accept the security prompt. It should then load up.
Mar 08, 2010 | Microsoft Windows XP Home Edition
Upgrading to Windows 7 from Vista with disks supplied by ACER
Try downloading CCleaner, which is free utility that will clean out all your temp files and also scan your registry for issues.
When a program is uninstalled, such as Kaspersky anti-virus, not all registry components are cleared out.
This is particularly the case if the program was a 30 day trial.
The registry retains details of the original installation to prevent consecutive 30 day trials.
CCleaner should clean it out. Run the Registry Issues component until it reports no issues found and then try your install again.
Feb 23, 2010 | Acer Aspire One PC Notebook
My wife has a Premiere Microscope Digital Camera, Model MA88, purchased in 2007. Her old laptop computer died on the 23 December 2009, necessitating purchase of a new laptop computer which had Microsoft...
Turn back to XP or buy one of those $150 mini laptops (netbooks) that run on XP like the acer aspire one, dell mini 9 or the hp onenote, and load the software for it there.
Dec 25, 2009 | Premiere Microscopes Science & Laboratory
Hi i am trying to upgrade my window 98 to window 7 but explorer won't let me download it how can i upgrade my computer to window 7
:L You Cant Upgrade From WIndows 98 To Windows 7 Your Pc is too old and The hardware is Gonna be outta date
Nov 16, 2009 | Microsoft Windows 98 for PC
Windows
If your computer meets the hardware compatibility requirements,
purchase Windows Vista Home Basic 32-Bit at this link for under
$90.00. Install it as an upgrade and your existing files will be moved
to a folder named Windows.old. If you choose to upgrade bear in
mind that Vista puts your system resources under a heavier load
so you may want to add more memory to your machine.
Nate P.
Mar 03, 2009 | Microsoft Windows XP Professional With...
321studios DVD X Show for PC Logo
157 people viewed this question
Top 321studios Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
Matthew Spark
Matthew Spark
Darial Jr Lasaria
Darial Jr Lasaria
Are you a 321studios Computer and Internet Expert? Answer questions, earn points and help others
