Tomtom GO 910 GPS Receiver Logo
Posted on May 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green light comes on but the screen and sound do not come on.
Had it in my truck it worked fine went to use it and the green light turned on and nothing else happened. Reset the GPS and tried again and nothing. let charge all night and still nothing. Took the unit apart no broken wires, cards and everything looks ok. any ideas
Archie Ferrarini
Level 3:
  • Master 869 Answers
  • Posted on Jun 02, 2008
Archie Ferrarini
Master
Level 3:
Answers
869
Questions
9
Helped
335369
Points
1789
Bad circuit board,sorry.
Trouble shooting
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
2answers
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
3helpful
Green light, black screens, no sound, needs new battery???
The alarm is just a coincidence i suspect, green light comes on and stays on probably not the battery at fault. It would be red.
If the green light goes out and screens just flash one of your screens are at fault or a loose ribbon connection.
1helpful
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
1helpful
2answers
VSX 7000 doesn't come on
If you still have an issue and the unit is out of warranty , give us a call at 415.637.9989 and we will see what we can do. DAVID
Flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
