Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Where is the reset button on the garbage disposal
    President:
  • 512 Answers
Underneath unit, red button. Also you should have a wrench that came with unit, it goes in hole under unit in center, you need to turn, to make sure nothing is stuck in unit.
Posted on Oct 02, 2010
Is there a reset button on badger 15ss?
Usually the reset button is located on bottom of disposal near where wire is connected..
Use your hair mirror to look at bottom of disposal.
More disposal resources for troubleshoot, maintenance, repair and installation:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Feb 25, 2015 | In-Sink-Erator InSinkErator Badger 3/4-HP...
Titan garbage disposal
Push reset button located bottom of disposal? Use broom stick and rotate stuck cutter disk?
Copy following link to troubleshoot by type of problem:
Titan appears to be repackaged sinkmaster garbage disposal.
There is no service manual or installation manual on brief web search. However link above has manuals sinkmaster and other brands .
Add a comment and say what you discover
Jun 09, 2013 | Garbage Disposals
Is there an override button is not clearing garbage
If disposal is not running, then push red reset button located bottom of disposal.
If disposal is clogged, Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal.
Oct 19, 2012 | Badger 1 Insinkerator 76039h 1/3 Hp Feed...
MY BADGER INSINKERATOR XP IS NOT SPINNING AND THE RESET BUTTON IS NOT RESETTING. WHAT WRONG.
It sounds like the garbage disposal has a fatal short, and the reset won't push in because there is an electrical failure inside the unit.
Nov 03, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I get power through the reset button. No humming, no nothing. Is it a bad motor?
If i understand correctly, you tested the wires where they connect to the garbage disposal.
Those wires connect before the garbage disposal reset button.
If the reset button is locked in, then the reset is not popped out.
If reset will not reset, then the popped-out reset will push in but not click down.
If the reset is clicked in, and you hve 120V on the line, and the garbage disposal doesn't make any noise, then the motor is bad.
There are no replacement parts for garbage disposal.
Oct 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
377 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
