Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
My wireless router keeps freezing up model # WPN824
YourTech
  • 63 Answers
SOURCE: how to add a laptop to netgear wpn824 router
access the router page and you will see the wireless settings. if your wireless network is password protected then you may have to enter the password in order for the wireless router to connect.
Posted on Oct 06, 2008
  • 17 Answers
SOURCE: neatgear wireless router wpn824 v2
Windows, if that's what you're using, may be connecting to a different router than yours. Verify that you're connecting to your access point.
Also, make sure there is a good connection between the router and your cable or dsl modem.
Finally, you can try connecting your computer to the router using an ethernet cable. That will at least let you verify that the computer and router work together, and you can configure the router and so forth. If connecting with a wire succeeds, that narrows the problem down to the wireless network connection.
Here's the manual. Troubleshooting is near the end, but it doesn't look like your specific problem is listed...
http://kbserver.netgear.com/pdf/wpn824_ref_manual.pdf
Posted on Jan 09, 2008
redhaze89
  • 854 Answers
SOURCE: Unable to Detect NetGear RangeMax WPN824
Step 1
No Wireless Connection Found in Range
1. Using a computer wired to the router, please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. For security reasons, the router has its own username and password. When prompted, please type in admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network.
a. Switch for the wireless adapter is turned off.
b. Distance between the wireless router and computer.
c. Possible wireless interferences.
Step 2;
Starting from the beginning...
Step 1: Checking the hardwired connection of your computer going to the router
1. If you are using Windows XP on your computer, you can check if your computer is able to communicate with the router. In most cases, the reason why you are having a ‘Page cannot be displayed’ error on your Internet Explorer is because your hardwired connection settings on the computer is disabled.
2. Please click on Start and go to Control Panel.
3. If you see ‘Pick a category’, please click ‘Switch to classic view’ on the left side panel.
4. Look for ‘Network Connections’ and open it up.
5. Look for any icon that says ‘Local Area Connection’.
6. Right-click on it. It should pop up a menu. The very first option can either be ‘Enable’ or ‘Disable’, whichever may be.
7. If it is ‘Enable’, that means you need to click ‘Enable’ to activate the hardwired connection. If it is ‘Disable’ then it is already been activated.
8. Once it is enabled, right-click the same icon and choose ‘Status’.
9. Go to ‘Support’ tab and please check the IP Address.
10. You should be getting information similar to this:
IP Address: 10.0.0.2
Subnet Mask: 255.0.0.0
Default Gateway: 10.0.0.1
11. If you have information similar to above, then you are able to communicate with the router. Please close the window and proceed to ‘Reconfiguring the router’.
12. Otherwise, kindly right-click again ‘Local Area Connection’ and go to ‘Properties’.
13. Under the ‘General’ tab, look for the box that says ‘This connection uses the following items’. Inside that box is ‘Internet Protocol (TCP/IP)’. Please double-click on it.
14. A window should pop-up. Choose ‘Obtain an IP address automatically’ and ‘Obtain DNS server address automatically’. Please click on ‘OK’, then another ‘OK’ to dismiss the window. Repeat step 8 to 11.
Step 2: Reconfiguring the router
1. Please disconnect your modem from your computer. Turn off your modem and set it aside first.
2. Using an Ethernet cable, please connect it to port no. 1 of the router. On the other end, connect it directly to your computer. Turn on your router. Check the lights (Power, Port number lights, etc.). If you placed the cable on port no.1, port no.1 light should be lit up.
3. Kindly access http://www.routerlogin.com/basicsetting.htm or 192.168.1.1 using Internet Explorer or any browser that you have.
4. If it asks for a username and password, use ‘admin’ and ‘password’ for the username and password, respectively.
5. Determine the type of connection you have from your Internet provider. Please follow and configure the corresponding steps for your specific type of connection for the Basic Settings:
- Does your Internet connection require a login?: Yes
- Select Other for the Internet Service Provider and enter your ISP’s username and password.
- Domain Name Server Address: Get Automatically From ISP
- Click ‘ Apply
9. After clicking ‘Apply’, the router will update its settings.
10. Please connect the modem with an Ethernet cable to the Internet port of the router. Make sure that no USB cable is connected to the modem going through the computer.
11. Unplug the router’s power adapter. Turn off the modem.
12. Power on your modem. Once your modem is stable, re-plug the router’s power adapter.
13. Check the power light, wireless light, Internet light, and port number light. The Internet light should be light green same as with the power light.
14. Try browsing the Internet. If you are not able to go online, restart the computer and try again.
Note: After following step 3, still you are not getting internet connection. Kindly proceed to step 4. Otherwise, you can proceed directly to step 5 for the wireless settings of the router.
Step 3: Getting wireless connection from the router
1. Again, please access http://www.routerlogin.com/basicsetting.htm or 10.0.0.1 using Internet Explorer or any browser that you have.
2. If it asks for a username and password, use ‘admin’ and ‘password’ for the username and password, respectively. If you have a different password for your router, use that password.
3. You should be able to access the NETGEAR settings page again.
4. Go to the left side of the screen (blue panel).
5. Please click ‘Wireless Settings’ and view your wireless settings. Modify your settings with the following:
- Name(SSID): (your own name)
- Region: United States
- Channel: 9
- Mode: g & b
- Security Option: WEP
- Authentication Type: Automatic
- Encryption Strength: 64-bit
- Passphrase: (leave this blank)
- Key 1: (type here your 10-digit phone number; example: 7183386814)
- Write down the contents ‘Key 1’ on a paper. (This will serve as your permanent network key that you will use as an authentication when you connect wirelessly.)
6. Please click ‘Apply’ so that the settings would be saved and updated.
7. Locate ‘Advanced Wireless Settings’ from the left hand side of your NETGEAR page.
8. Make sure that the ‘Enable Wireless Router Radio’ and ‘Enable SSID Broadcast’ are checked. Kindly click ‘Apply’ to save the settings.
9. Please click on your Start Button. Click ‘Run’.
10. Type ‘services.msc’ on the ‘Run’ window then press OK.
11. Look for ‘Wireless Zero Configuration’ and double-click it.
12. Change the ‘Startup Type’ to ‘Automatic’ and click ‘OK’.
13. Please disconnect the Ethernet cable from your laptop so that you can go wireless. Restart your computer.
14. Kindly right-click the ‘Wireless Network Connections’ icon (monitor screen icon) on the bottom right corner of your screen near the time.
15. Choose ‘Open Network Connections’. It should open the ‘Network Connections’ window.
16. On the ‘Network Connections’ window, please right-click ‘Wireless Network Connections’ and choose ‘Properties’.
17. Go to ‘Wireless Networks’ tab. Check the ‘Use Windows to configure my wireless settings’.
18. On the bottom, look for ‘Preferred Networks’.
19. Please click each network that you find on that box and click ‘Remove’. You need to delete all the networks including yours.
20. Click ‘OK’ to exit.
21. Kindly right-click the ‘Wireless Network Connections’ icon (monitor screen icon) on the bottom right corner of your screen near the time. This time, choose ‘View Available Networks’.
22. Please click ‘Refresh network list’ on the left-hand side to re-detect the wireless networks around you.
23. Please click the name of your network (your first name) and then click ‘Connect’ down at the bottom.
24. It will ask for a WEP key or a network key. Kindly specify the network key (your phone number) which you have set from the NETGEAR router and click ‘Connect’.
25. The window will say ‘Acquiring network address’ and eventually will become ‘Connected’.
26. By this time, you can now try browsing the Internet again wirelessly.
Posted on Apr 25, 2009
  • 40 Answers
SOURCE: can't install my netgear wpn824 wireless router
You can download manuals and software from netgear.com
Posted on Apr 29, 2009
anandg27
  • 1272 Answers
SOURCE: Trying to connect wpn824 router though dsl with Windows 2000
First make sure that you can access internet through the router when connected to it wired. If yes, then please perform the steps below to configure settings:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'.
6. Set the 'Authentication Type' as automatic.
7. Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
10. Click on Wireless Settings under Advanced in the left hand side menu.
11.. Click on Setup Access List. Uncheck the option Turn Access Control on and click apply.
Scan for the wireless network on the computer with the wireless adapter and connect to your network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 18, 2009
How do i set up my router? model # WPN824
Check this url http://static.highspeedbackbone.net/pdf/netgear-WPN824-manual.pdf.
Oct 26, 2010 | NetGear RangeMax WPN824 Wireless Router...
Just got wpn824 and having problrms with pppoe login and pass. Using att dsl ...but that login isn't working
You'll need to set your DSL modem up for "bridge mode". Right now it's acting as a router as well and that's keeping your new router from making the connection. In bridge mode, the modem acts only as a modem to connect to AT&T. Then your router will provide your login information and your computers will connect through it correctly.
You don't give your modem model so I can't give you any specific directions. A Google search for "bridge mode" and your modem's make and model should turn up the information you need. Or you can call AT&T's technical support number and ask them how to configure your modem. (Sometimes these big ISPs aren't too keen on helping you, though. They'd rather supply you with a wireless router/modem at an extra charge.)
Hope this has helped. Thanks for using Fixya!
Feb 15, 2010 | NetGear RangeMax WPN824 Router
I can't connect to internet wirelessly, though my
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 16, 2010 | NetGear RangeMax WPN824 Wireless Router...
My Netgear wireless network is apparently not secure, my neighbour can use it. I am not sure how to secure it.
Setting up security is somewhat involved. Rather than try to give you step by step instructions here, follow this link to the WPN824 reference manual and go to page 46 to look at security options and setup. It will start with WEP, but I would suggest you keep reading and consider using the stronger WPA.
http://www.google.com/search?hl=en&rls=com.microsoft:en-us:IE-SearchBox&rlz=1I7DKUS_en&q=netgear+wpn824+setup&revid=5582131&ei=AlnSSuGpLIuKswOE0v3vCw&sa=X&oi=revisions_inline&resnum=0&ct=broad-revision&cd=2&ved=0CCIQ1QIoAQ
Oct 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Need my passphrase for my netgear wpn824 wireless router
Are you trying to setup your router? If so..
Here is a list of Netgear WPN 824 Models. :) USERNAME PASSWORD
Netgear WPN824 v2 (Netgear Firmware) admin password Netgear WPN824 v3 (Netgear Firmware) admin password
Netgear WPNT834 (NetGear Firmware) admin password
Jan 07, 2009 | Computers & Internet
Connect netgear wpn824 to DSL router using usb connection between DSL router and wireless router
call your ISP. Change the DSL modem from USB connect to ethernet connect. There is no possible way two match the two device
Dec 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
How to add a laptop to netgear wpn824 router
Oct 05, 2008 | NetGear RangeMax WPN824 Wireless Router...
Can't reconnect - NetGear RangeMax WPN824 Wireless Router
Try changing the channels of the router to 1,9,or 11. this may help minimize wireless interference.
Mar 27, 2008 | NetGear RangeMax WPN824 Wireless Router...
Reset
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Dec 15, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
256 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
