Question about Stanley Bostitch MIIIFN Flooring Nailers
Staples wont penetrate wood and keep foldin up
  • 37 Answers
Are the nails proper for nailer? the gauge of the nail is important
Posted on Oct 02, 2010
    Scholar:
  • 67 Answers
You should be using a cleat nail with this product not a staple. Staples are not strong enough to penetrate the wood which is why they are folding up. I'm assuming you are nailing down a hardwood floor. Also make sure the magazine never gets below 30% nail capacity. If there aren't enough nails in the magazine they could bend when firing and come up through the hardwood instead of nailing it down.
No matter how i hold the staple gun the staples won't go into wood. when they do the staples aren't flat they bend in the middle.this gun has never worked correctly.could i be using it incorrectly?
possibly that you are not using the correct staples
staples for wood have a chisel shape at the points and depending on the wood hardness will be shorter that normal
Jan 28, 2017 | Tools & Hardware - Others
The staples wont penetrate the paper - they keep bending before they go through the sheets.
Ensure the staples are the correct size. If you check the end of the stapler, at the bit where the staples are bent by being pushed against, there may be 2 different width of rexess for the staple to c go in and be compressed....if it is set to the wide setting change it to the narrow setting. THAT MIGHT CURE IT, IF THE PROBLEM PERSISTS TRY BEYING SOME BRAND NEME STAPLES SUCH AS REXEL
Jul 06, 2015 | Staples Office Equipment & Supplies
What staples does a black and decker electric stapler 9700 take and where can I buy them?
Hi Stephen,
Of course the manual states to use their staples for best results.
However it does at least state it is designed for a wide variety.
Most hardware stores have a range of staples to choose from.
Home Depot, Harbor Freight, Lowes etc. Try a chisel point this may help penetrate the wood deep enough. All staples are not made the same. So again trial and error may be the quickest route. Fortunately you can purchase small boxes for your testing.
The manual for this stapler is here:
(Page 2 talks about the staples to use.)
Black Decker 9701 Instruction Manual Page 2
Good luck and hope this helps!
Jan 04, 2015 | Arrow Tools & Hardware - Others
How to stain wood veneer
You would need a stain that would penetrate the wood veneer. A good oil based stain should be able to penetrate all the way through. Lightly sand the face of the veneer with 220 grit or higher sand paper. I use a sanding block made out of rigid foam and sand by hand. You will need to keep the veneer wet with the stain until it penetrates. I would stain both sides of the veneer until it penetrates to the depth you desire and then wipe off any remaining stain. You may need to press the veneer until it dries thoroughly! Good luck.
Mar 21, 2014 | Crafts & Hobbies
T59 arrow stapler doesnt set staples all the way into wood
Is this just on one piece of wood or does it act that way on all kinds of wood? Some wood is denser that others and that would cause the staple to not go completely into the wood.
Jan 13, 2014 | Arrow T59 Cable Stapler For Insulated...
The side of the staper lists 3 different staple sizes, does it really take all 3? (1/4, 3/8, 1/2 inch)
Samantha, Yes. These sizes are the lengths of the legs. They are all the same size wire, bent into the same width of "U". Yes, it will take all 3, but you have to buy the right type. When you buy staples, look for compatibility with this brand & model stapler. By the way, if you a stapling something thin to something substantial (such as paper to wood), use short staples. Otherwise you will have difficulty getting the staple to penetrate the wood sufficiently for the staple to lay flat. Good luck, Al K
Dec 08, 2010 | Powerfast Stanley TR110 Light-Duty Staple...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Wont shoot staple right in and looses air through top
Try a few drops of lubricating oil designed for compressed air tools.
If the diaphragm is only stuck this may help.
If the diaphragm is damaged or cracked. This won't help. It will need replacing. This will result in lower air pressure causing the staple not to penetrate deep enough. And will allow air to by pass the diaphragm straight out the top of the unit.
Hope this helps!
Nov 17, 2009 | Tools & Hardware - Others
Arrow ET200 nail gun only put nails in 1/8 of inch.
This electric nail gun does not have much power. Try shorter nails and softer wood. You need a pneumatic nail or staple gun for medium or heavy work. I have both a nailer and stapler and neither are very good.
Jul 23, 2009 | Arrow ET200 Electric Brad Nail Gun
The staples do not enter the wood completly
often when squeezing the tool the front gets lifted and the staple does not set fully. try making sure the front is tipped down fully and in contact wood when it fires. if that doesnt work the push rod is not working properly and is easier to replace than try to fix
Apr 22, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Stanley Bostitch MIIIFN Flooring Nailers Logo
505 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
