Question about LG Washing Machines
Will not drain, hose are not pluged and screen is clean also have miner water coming out of vent in back
    Problem Solver:
  • 17 Answers
Just call me on +263912639492, thta's easy.thank you.
Dr. Kelson
Posted on Oct 02, 2010
Nf code, new cold water valve, cleaned screens, drain good, uplugged and pluged back in still no cold water
trying turning the water off. disconnecting the hose at the valve and hooking it up again.
Feb 02, 2015 | Washing Machines
Firewall wattwr hole 97 town&country
This happened to me. The problem is that the drain is clogged. Remove the wipers and the vents under the wipers. You will probably see a lot of dirt and dead leaves in there. use a shop vac to clean the area. Then find the drain hole. There are two of them, one on the left and one on the right both lead to a hose going down on the sides of the engine. Remove both hoses. Clean them out and also clean out the drain hole as well. I used a screw driver to clean them all out. Then with a water hose, pour some water through the hoses and drain hole with a very light pressure. You should see the water going through the drain hole and also see the water going through the hoses that go to the bottom along the sides of the engine. This has solved my problem. This usually happens when you park under trees a lot or the vents are not protected from debris. If in fact the vents do not have a screen on it, then just pick up a role of aluminum screen at Home Depot for under $10. Easily place the screen under the vents with very small screws or just use a staple gun and just cut off the remaining screen. Hope this helps you out. Good Luck!!
Feb 17, 2012 | 1997 Chrysler Town & Country
Water is coming out of the AC vents inside the car
DRAIN HOSE FOR AC NOT OPEN (PLUGED) YOU SHOULD SEE IT UNDER CAR AT R/ FRONT UNDER FLOOD BOARDS FOR PASSIGER OR A LITTLE FORWARD. IT WILL BE CLOSED UNTILL WATER OPENS IT UNLESS PLUGED. FIND IT AND PUSH WIRE CAREFULLY UP IT AND IT SHOULD DRAIN AND BE OK FROM THERE. THE HARD PART IS FINDEING HOSE GOOD LUCK
Jul 23, 2011 | 1996 Oldsmobile Cutlass Ciera
I have water coming into the freezer through a vent in the back. Where is it coming from and how do I stop it?
Hi and welcome to FixYa, I am Kelly.
Your freezer evaporator drain is clogged. Unplug the unit.... open the lower back of th unit by remvoing the fiberboard cover. Place an external fan directed into the freezer compartment for just over 2 hours. (Water mess) Use a vacuum to clear the debris from the catch pan basin in the bottom of the unit. Make sure to clen off the END of the compartment drain hose. Next revers the vacuum flow to exhaust. Force aire throught the end of the comaprtment drain hose to float out any debris in the evaporator drain funnel. Clean up the residual water and return the unit back to normal service. This should stop the water thatis caused by the automatic defrosting cycle from comeing through the evaporator acess panel vents.
Thanks for choosing FixYa,
Kelly
Jun 06, 2011 | Admiral Refrigerators
WHAT DOES IT MEAN WHEN MY WASHER STOP STOPS & SHOWS LF OR F1? i CAN'T READ IT!
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
Feb 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore elite oasis model 110.27032600 LF error. had an issue with the washer cycling through all the lights, would turn it self on etc. Had the repair man come out and he replaced the computer board....
Feb 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Dishwasher will not drain. We cannot get the screen out to check for clogs. There is a grey plastic box that prevents the screen from coming out.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Dec 13, 2010 | GE Profile PDW8480JSS Built-in Dishwasher
My electric dryer heats up but doesnt dry the clothes
If your vent hose is more than about ten feet long, your dryer may not have enough pressure to keep the air moving sufficiently to dry the clothes. Is it possible you are simply over loading your dryer?
Jan 25, 2010 | Kenmore 63942 Dryer
Dishwasher leave debris on dishes
there is no filter except the screen in the water inlet valve to keep big pieces of grit in the water from defecting the inlet valve..
i dont know exactly why but it sounds like your unit was not installed with a recommended air gap in the drain or something similar and somehow dirty sink/drain/sewer water is making its way back into the unit and onto your dishes.
often times there is a little rubber check valve/flapper in the drain line either installed in the pump or the drain hose just after the pump to keep foreign material from entering the unit..
other than that it would just be mineral and calcium deposits if you are on well water or chunky city water..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Maytag 24 in. MDBH940AWS Built-in...
Kenmore series 80 12 years old
hey thats eazy.your washer has a water fill valve.the two black hoses go to it in the back.inside the valve where the hoses attach their are screens that keep minerals from going into the water valve.also some have screens on the other side off hose too,and after cleaning run the water thru the hose into the drain/sink because minerals may be backed up in house line or hose.If dosent improve after this its in your water valve and theres nothing you can do but replace the water valve they dont come apart for cleaning,or could take apart but looking for trouble because wont then seal and will over flow on to floor.you can do it .God bless ,tom
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
