Question about Husqvarna Garden
Husqvarna 150 bt leaf blower. runs good for about 10 minutes then starts to make a metallic pinging sound and drastically losses power, but still idles and runs smoothly at lower speeds. it is about 1 and a half years old
  • 37 Answers
If your gas oil mixture is right then try buying different gas the ethanol in gas is ruining all small gas motors!
Posted on Oct 02, 2010
Testimonial: "thanks for your answer. I tried new gas, oil mix with 97 octane, helped some, "
  • sloopster Jul 11, 2011
    mine is doing the same exact thing, after same amount of time too, probably 25-30 hours of use. I always buy highest octane gas and am careful to mix oil in proper ratio. Is high octane gas also high in ethanol? Tried cleaning air filter. Thinking carbourator...
I also have the same model with the identical ailments. The fuel mixture is the same as used in my Stihl chain saws. I've taken the carburator apart and found no signs of dirt or obvious obstructions. My next step will be to check the muffler for possible carbon buildup. With these posts as a reference, it appears we might all have lemmons on our hands.
Posted on Nov 02, 2011
Why won't my Husqvarna 150 BT blower shut off? It starts and runs great, but won't kill with the switch.
Kill switch most likely has broken wire between switch and engine. When in "kill" position, it should connect the top of the sparkplug to the rest of the engine. If it doesn't, either the switch is bad or the wire is.
Jun 15, 2015 | Husqvarna 150BT 50CC Gas Leaf Backpack...
It won't start
How long has the gas been in the Blower?
If it was 10% Ethanol gas( lie most States sell at the gas pump) and it has been in the Blower for more than a few months, you probably have carburetor issues.
Oct 25, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
Husqvarna Repair Manual
Have you used the correct fuel and oil mixture.?
If its new and still under warranty then take it back to your local dealer.
Here's the parts manual
May 08, 2013 | Husqvarna Backpack Leaf Blower 350 Bt Yard...
HUSQVARNA 130BT GAS BLOWER STARTS FINE, BUT LOSES POWER WHEN I TRY TO USE????
Sounds like a fuel starvation problem, Strip and clean carb. Avoid using airlines to clean carbs. remove low and high adjustment screws, reset to factory settings. Walbro carbs are generally scew both of them back in all the way and then turn out 2 full turns each anticlockwise.
Mar 02, 2013 | Husqvarna 130bt 130 Bt Gas Powered...
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
I have a Husqvarna 150 BT X Torg. It is 2 yrs old & it starts but dies & I start it again but oes the same thing in just a few minutes. HELP
Hi and welcome to FixYa, I am Kelly.
The symptom your describing is most often caused by the primer bulb/pump getting a pin hole in it. See this link Item 17: (PN 544363901)
http://www.partstree.com/parts/?lc=husqvarna&mn=150+BT+(2008-10)&dn=89_55_0033
It can however be caused by diaphragms that have failed inside your WYA-79 carb. If you do not have a primer bulb problem the next step is to rebuild the WYA-79 carb with a diaphragm kit.
net IMAGE search using this: Walbro "WYA 79" "Carburetor Kit" They average $13.99
The carb Manual:
http://wem.walbro.com/distributors/servicemanuals/WYAseries.pdf
Dried and cracked fuel lines can cause the same symptom you describe also.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Husqvarna Garden
I have a Hasqvarna 150BT blower that started to make a knocking noise at full power and has lost some power. Seems to start ok. Loss of power / rpm and knock are only ploblem?
I had the same issue with a Husqvarna 150 BT blower. Brand new ran through 2 tanks of gas and need to buy more gas , mixed 50 to 1 ratio 87 octane on new gas which was the same as what i was running and it started pinging and running like **** then stalled and would not start. took the plug out and it was fouled. cleaned the plug got it running again but still not good. This model comes with a NGK CMS7H plug which i replaced with a champion RZ7C and new gas 93 octane and lawnboy oil mixed 50 to 1 ration and now its running like a champ. I've had bad experiences with NGK spark plugs in the past and thought this may resolve the issue and it did. Hope this is helpful to anyone out there having the same issues. Also used some fuel stabilizer in the fuel mix, I hear this helps with the ethanol problem in the fall/winter gas.
May 13, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Garden Logo
647 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
