Lcd tv hi , i have a goodmans tv that has developed a thin verticle blue line on the screen . looks as if its done by a ruler its that straight . definately on the screen . any idea what this is and can it be rectified. chris
    Problem Solver:
  • 7 Answers
The LCD liquid crystal is damaged I believe
it wiould need to be repaired by a TV shop copuld cost a bit to repair
Posted on May 30, 2008
Verticle thin blue line on my IBM ThinkVision Monitor?
it may be a permanent damage on your monitor. i think it is unrecoverable.
Jul 16, 2017 | IBM ThinkVision L200p 20.1" LCD Monitor
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
Verticle line running down the screen.Thin verticle line running down the screen.
You have a defective LCD panel. The only way to fix it is to replace the whole LCD panel. It is the most expensive part in the TV (usually $500-2500) depending the make, model, and size. It is also time consuming as you need to take the whole TV apart in order to replace that part.
Oct 09, 2009 | LG Televison & Video
I have a VS10576-1M and it has green lines horizontally across the picture. Is it worth fixing or getting the part?
If they are static and not moving, kida look like someone took a thin magic marker and a ruler and drew a straight line across the screen, then it is the panel and the cost of repair would be prohibitive.
Sep 02, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Mitsubishi LT46-144 LCD Verticle Line Problem
Go to Mitsubishi support page, look at warranties (scroll down) and see if your model is under the extended warranty section. Then if so have a tech repair person come look at the picture and order the parts while you keep the tv. Parts and labor are covered.
Mar 14, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Single verticle line running through screen on lcd flat screen
Hi Emma,
It could be a connector problem between mainboard and your display.
Often it is repairable, but if your tv is 1 year old there's still some waranty left.
Kind regards,
Gerard
Jan 29, 2009 | LG 42LG50 42 in. LCD HDTV
I have a black line accross my LCD t.v. screen
if it is a thin black line then it is probably a line of pixels out. if this is the case, the whole screen will have to be replaced and that can get pricey. i would suggest that you get it checked out by a tv tech and get an estimate, but it'll probably be cheaper to just get a new one
Oct 21, 2008 | Televison & Video
Problems with my Mitsubishi hd1080
Most likely you are looking at conversion chip problem. The replacement price on these can varry widely. It may be cheeper to look into purchasing a flat panel lcd or plasma tv.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Computers & Internet Logo
353 people viewed this question
David Payne
David Payne
