Question about GE (PSS26MSRSS) Side by Side Refrigerator
The blower in the front or back and the divider betwwen fridge and freezer is very hot . what to do ? how long can i turn off unit before everything defrosts?
    Problem Solver:
  • 17 Answers
Just call me on +263912639492, thta's easy.thank you.
Dr. Kelson
Posted on Oct 02, 2010
HOT SPOT IN FRONT DIVIDER BETWEEN FRIDGE AND FREEZER
Greg,
That is usually a heating element that is used to prevent condensation from developing in that area. It should cycle on and off and be slightly warm, but not get real hot. Check around your controls and see if there is a switch for something like Energy control or something like that, the exact term is escaping my memory, and you might be able to turn it off. Hope this helps!
Jul 12, 2015 | Admiral Refrigerators
Wall dividing fridge from freezer is very hot to the touch
You either have obstructed coils (lots o dust) under the fridge or the fan that is supposed to draw air across them has ceased to work. Check the coils and clean as necessary, and check the fan. Maybe you will get lucky and find something caught in it. If the fan is not working, leave the back cover off the fridge and put a small window or box fan back there until you can get the fan replaced. The fan will keep the fridge running for you in the meantime.
Jun 29, 2010 | Refrigerators
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
Center of side by side very hot center between doors very hot whirlpool 25 cu. ft
If by the center bar, you mean the divider between the freezer and fridge sections, then the heat you're feeling is the built-in condensation heaters designed to keep moisture from forming on the exterior of the unit. These heaters also help to keep moisture from freezing on the inside of the door edges and in between the sides of the unit as well.
It's a normal function of modern, frost-free refridgerators, Some brands/models have an "energy saver" switch inside the fridge section that you can use to turn off the extra edge heaters, if you aren't experiencing excessive condensation forming on the outside of the unit.
Not all the heaters can be turned off even with fridges that have an energy saver switch, as the manufacturers engineer/determine where and how many edge heaters are needed to get the best performance out of their products.
With an energy saver switch, you turn it "ON" to actually turn off the surface heaters, and turn it "OFF" to have the heaters run constantly. Thus having it "ON" saves the energy that would be used to keep the heaters very warm. Some manufacturers have added electronic sensors to regulate these heaters, but not all makers have done this.
You should also clean the coils to help the fridge run better. As far as getting to the coils to clean them, if you have a long narrow crevice tool with your vaccum, you can try to use that to get underneath the unit to carefully get the dust out. I found that if you move the unit out where you can get to all sides, makes it easier to remove any dust on the back and underside of the fridge. Don't foget that you might have to remove the lower, back access panel to get at the compressor/coil assembly.
Just unplug the fridge first to keep from ruining your spouse's vaccum tool in the cooling fan blade, like I did once and never he-ad the end of it! (Not to mention the noise it makes - brought her running to see what I was doing!)
If that isn't possible, you can always use the blower end of a vaccum to blow out the coils, but it's a messy proposition at best. I've used a swiffer taped with some duct tape onto a long, thin dowel to get quite a bit of the dust the vac couldn't $uck out - I prefer that to blowing dust out as it's less messy.
Provided your fridge and freezer are cooling properly, you shouldn't have any issues with the warm center compartment divider causing you any problems.
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Whirlpool Refrigerators
Side by side. Front edge of divider between fridg
There is a heater there that reduces condensation. If you have a switch that has energy saver mode, that would turn it off
Sep 04, 2009 | Refrigerators
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Heat build-up
Had this same problem and turned out that the coils at back of fridge and below doors were covered in dog hair. After vacuuming, area is no longer warm.
Aug 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Samsung side by side center divider front extremely hot
That sounds like you may have something in your condenser fan motor.. piece of bag, paper and may have stopped your fan altogther.. that would be the first place to check.. right by your compressor in the back of frig.
Aug 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
