Question about IBM ThinkPad R40 2722 Notebook
Password i have ibm thinkpad and i remove cmos battery.then i found message the time nd date setting change and then asked me a password.which is i m no know please solve my problem
  • killeekillee Jun 03, 2008
    i remove the cmos battery then when i turn on my notebook i receive an error 0271 then a power-on password appears which i don't know
  • singhrb24 Jun 30, 2008
    cmos
  • 868 Answers
Your dealing with more than one security.Save time and replace the hard drive.
Posted on May 26, 2008
    Scholar:
  • 139 Answers
Is it a cmos password or a hard drive password which be specific i think we can help u.
HI, I have a IBM Thinkpad R50e and i had a CMOS battery failure. After replace the battery it has now started to ask me to check the date and time and when i press enter it is asking for a BIOS...
Dear john, replacing CMOS Battery usually RESET password ( plug out your laptop battery,then plug out the CMOS battery. keep it out for 5 minutes.)
After 5 minutes by, put back on the CMOS battery. put it back all together. laptop battery the last one.
On the first boot you need to set the time and date. or by pass it by pressing ESC. >> If your Operating System goes >>> right click on clock task bar >>Adjust Date/Time >> set as you wish >> apply >> ok >>>RESTART your unit.
akee_akee@live.com
Aug 16, 2011 | IBM ThinkPad R50e Notebook
I HAVE A IBM THINKPAD A22M LAPTOP WHEN IT BOOTS IT HAS A ERROR CODE OF 0271 CHECK DATE AND TIME SETTINGS AND BLANK SCREEN APPEARS AND A LOCK ICON APPEARS.... IT PROMPTS FOR A PASSWORD I DONT KNOW THE...
You will most likely have to remove the backup battery temporarily to allow the CMOS to clear the password lock.
The instructions for removing the CMOS battery are located here.
Be sure to disconnect the power cord and remove the standard battery when performing this work.
Be very careful to follow the directions exactly as shown.
You may have to leave the CMOS battery removed for a number of hours in order to clear the CMOS password.
Dec 29, 2010 | IBM ThinkPad A22m 2628 Notebook
I accidently removed the cmos battery of ibm thinkpad t30. After that error 0271: time and date setting appear then power on password show up. I failed to get into bios to change the time and date setting...
Removing the BIOS battery will not remove the BIOS password because the password is stored on an EEPROM chip. The password can be retrieved with difficulty, it requires you to build an EEPROM chip reader. For instructions to remove this password, please click on this link :-
http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Dec 06, 2010 | IBM ThinkPad T30 Motherboard 91P7695 -...
GOOD MORNING SIR / MAAAM.. MY IBM THINKPAD R50E HAS AN ERROR ON THE SCREEN ..."ERROR 0271 CHECK DATE AND TIME SETTINGS'.. HOW DO I CLEAR THE CMOS FOR THIS ERROR? HOW DO FIND THE PASSWORD PADS ON THE...
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS Battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new battery you can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the battery out or replacing it will get past your lock icon asking for the password. If not then you may have to find out the manufacturer of your computer's motherboard to see if there is a common password to get past the lockout. Since it's a laptop then it should be easier to find this code based on the manufacturer.
These links may help you with that:
How do I Reset an IBM ThinkPad BIOS Password?
CMOS Password locked on IBM Thinkpad
Nov 09, 2010 | IBM ThinkPad R50e Notebook
I have 0271 error can get into bios but not able to change the date and time??
The error means that you have to change the BIOS battery first before trying to change the date and time.
As far as i know with IBM's the CMOS (RTC) battery is located under one of the panels underneath the laptop and is usually covered with red, blue or yellow plastic with wires coming from it. Disconnect the battery and replace it
Once the CMOS battery is replaced you can set the date and time and no more error messages.
Regards.
Jan 24, 2010 | IBM ThinkPad T60 Notebook
Thinkpad R40 find date & time for start-up
Right-click the time in the lower right, select: adjust date and time, select: internet time, select either source, select: apply (if high lighted)--otherwise close. You need to be connected to the internet for the internet time to work.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Removing CMOS battery on ibm r50e is not solving the pass problem
Removing battery or resetting BIOS with jumper will not help. You should call IBM for support on this issue. All thinkpads have a three year warranty, with either return to base or on-site service. Since the R50e is a recent model, you should have no problem getting it serviced directly by IBM. Toll Free: 1-800-IBM-SERV (1-800-426-7378)
Jun 25, 2009 | IBM ThinkPad R50e Notebook
0271 error
go to the bios and set the time and date there. you also may need to load the default settings to reset the bios to remove any bios passwords. if that does not work remove the bios battery or move the bios jumper for one minute. to reset it write down all bios settings befor you do it.
Jun 22, 2009 | IBM ThinkPad T21 Notebook
My IBM Thinkpad is not switching on?
The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
Mar 15, 2009 | IBM ThinkPad T21 Notebook
My ibm thinkpad r40e is asking for CMOS password what to do
You will have to enter the bios and reset the date and time, but you might need a new cmos battery.
Re the cmos password, you should remove it, but will have to know what it is. This can also be done while you are in the bios.
Mar 14, 2009 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 2722 Notebook Logo
163 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
