Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
How do I change the saw blade on my 2 hp 7 1/4 saw?
    Scholar:
  • 67 Answers
If the saw doesn't have a locking mechanism for changing the blade then you will have to jam a piece of wood in the teeth of the blade so that it cannot turn. Remember safety first. Ensure the saw is unplugged and wear leather gloves when changing the blade. Use a socket or wrench to loosen the nut that holds the blade on and remove the blade. Use the reverse procedure to tighten the blade.
Posted on Oct 02, 2010
  • 37 Answers
Unhook saw if it does not have a lock button near the handle you have to secure the blade and take center bolt out should be a wrench on the deck of saw after bolt is out remove and replace blade and tighten back up
Blade wont cut all the way down when cutting baseboard
the maximum cutting depth of a circular saw is the distance from the teeth to the drive washer hub of the saw blade
so on a 7 1/2 saw the effective cut would be less than 3"
if your base board is thicker than that get a bigger saw
it the board is a lot less adjust the cut depth adjustment for the saw base
Nov 19, 2016 | Saws
Why does the blade stop working on my circular saw when I'm using it
Your either pushing the saw crooked into the cut or the nut holding the blade it loose. Make sure you unplug it before you start fooling around with the blade.
Oct 13, 2014 | Skil 7 1/4" Circular Saw Corded 2.5 Hp...
Manual for 1.3 hp Craftsman band saw
The blade length of the saw is 70.5" . You can get custom length blades on www.sawblade.com . You may visit sears site to get manual for that saw.
Jul 26, 2013 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
My combination saw D27105 is making a bad noice when attempting to start and is not running up to normal speed. can anybody help here ?
it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Jul 31, 2010 | Dewalt DW745 10" Compact Job Site Table...
Blade guard broke
Go to Searspartsdirect.com and list the complete part number minus the decimal point. You will get a series of drawings of replaceable parts and can order from the site. Good luck!
Apr 17, 2010 | Craftsman 7-1/4" Circular Saw Blade Pack
Instructions to install blade on circular saw
Once you have the right size blade it is really simple to change it.
You only really need two things.
1. locate the button that locks the spindle. It is usually located on the body of the saw. Your manual can show you a picture of it.
2. You will need a 3/8 drive socket that fits the spindle bolt.
I believe these are standard thread orientation and come off counterclockwise.
Mar 20, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
754 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
