Question about Plantronics Voyager PRO Bluetooth Headset
Plantronics voyager pro continuous beeping, appr 1 beep/sec
  • 91 Answers
SOURCE: need to reset plantronics voyager pro heatset it
to reset or pair your bluetooth device you need to put the device into discovery mode.To do this most manufactures use the power button,by holding the power button down for 8 to 10 seconds while turning the device on it should put it into discovery mode.Usually a light will remain on then you can find or search from your phone for new device.Once your phone has discovered the device it will ask for a pin\pairing code .Once again most manufactures use a 4 digit pin\pairing code they are as follows,0000,1234,9999, or 1111,try them in this order one will work. Hope this helps
Posted on Mar 23, 2011
HDI Headsets
  • 537 Answers
SOURCE: 8xx plantronics blue tooth will
This issue may be caused by the network and not a defective headset. Changing your phone settings as listed below will in most cases stop the frequent ringing/beeping in your headset while in standby mode. You may want to check with your service provider before changing the settings listed below, as the following activity may cause additional charges on your phone bill. If you can, remove and re-install the phone battery. This should reboot the phone. Go into the MENU > SETTINGS > ROAM. Change roam setting to "ROAMING ONLY". Users will no longer get any Bluetooth headset rings/beeps unless the phone is actually ringing for an incoming call. This is a temporary work around since once the phone is turned off, the roaming setting above is reset. You will need to follow these steps each time you turn on your phone.
Good luck from Headsets Direct!
Posted on Sep 07, 2011
HDI Headsets
  • 537 Answers
SOURCE: my plantronics voyager pro will not charge turn on
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Posted on Oct 24, 2011
HDI Headsets
  • 537 Answers
SOURCE: I cannot connect my Plantronics
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Posted on Oct 27, 2011
HDI Headsets
  • 537 Answers
SOURCE: how do i put a plantronics voyager pro into
The instructions on the link below will walk you through the pairing process:
Caller says voice is breaking up
Try deleting the Voyager Pro from your phone. Turn your phone and headset off and then back on after about 30 sec. Now reconnect the headset to the phone and see if that helps. See page 8 of user guide for further tips. User guide attached below.
Plantronics Voyager Pro User's Guide
Aug 31, 2011 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Voyager 500a bluetooth system. was using the lifter, but don't want to anymore, just want to be able to switch phone to headset mode and use the bluetooth. When I hook it up and hit the...
The beeps mean it needs to be repaired or resubscribed.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
If you are using a Cisco phone you could probably plug the headset base into the phone. If it is not you will still need your lifter.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Continuos (3) beep beep beep when voyager pro is turned on
Triple tones are usually associated with the battery having a very low charge. You should be getting approximately 5-6 hours of talk time and 5 days of stand by time from a single charge. If you are not, then the internal battery may be going out. The battery is hard wired and is not replaceable, however the headset does have a one year warranty from Plantronics and they will replace it within the warranty period.
Aug 17, 2011 | Plantronics Voyager PRO Bluetooth Headset
My Plantronics Blue tooth earpiece gives a constant "three beep" sound. I can hear the other person on the phone but the constant beeps at the same time. The beeps happen also when the phone is...
The three beeps usually indicate low talk time. If you have tried turning off and on your headset and still have the annoying beeps, then there is a problem with the device. You'll need to contact your retailer or Plantronics (800-544-4660 x5538) for warranty replacement. If it's out of warranty, check out our website Headsets Direct for the latest in Bluetooth headsets.
Jul 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
My Plantronics Voyager Pro begin emitting a continual ringing when I pair to my Blackberry. I've tried deleting the headset and re-finding it and it still rings when connected. This issue first appeared...
It sounds like a defective headset. Call Plantronics directly at 1-800-544-4660 x 5538 to troubleshoot and if it's defective, they will assist in a replacement.
Good Luck from Headsets Direct!
May 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
I connected my plantronics voyager pro to my blackberry bold and they connected fine (never asked for passcode) but there is a continual beep in the back round that makes the sound of the other call be...
Try to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
May 02, 2011 | Plantronics Voyager PRO Bluetooth Headset
My voyager pro will auto pair with my samsung gt-b2710 but then disconnects after 5 seconds
I would suggest deleting the Voyager Pro from your phone. Turn your phone and headset off and then back on after about 30 sec. You will need to reconnect the headset to the phone again. Use pass code 0000 (4 zero's) if you phone ask for it. See page 8 of user guide for further tips. User guide attached below.
Dec 11, 2010 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Voyager PRO  Bluetooth Headset Logo
2,222 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
