Question about Hampton Bay Heating & Cooling
Took down ceiling fan to paint . one of the blades is warped real bad because of the way it was sitting . can i order replacement blades or do i need a whole new unit
    President:
  • 512 Answers
They sell replacement blades at homedepot. They carry hampton bay. You need to replace all blades. they come in a pack, they are all the same weight so fan will be balanced. They also sell replacement brackets that are also balanced
Posted on Oct 02, 2010
We have a white ceiling fan, model # 20709-300, and we need to replace the blade arms in white. The original blade arm number is 92496. Please help.
why dont you save some time and money and go to home hardware and get some white spray paint idid this to my fan blades worked great
Jul 30, 2011 | Hunter (25417) Ceiling Fan
Hunter breeze low profile ceil fan, 5 blades 3 lights, Wobbly
Can you describe the mounting bracket for this fan?
If it is a ball mount, then there is a groove in the ball that connects to a tab in the mounting bracket. if the tab is gone or the ball is not sitting down in the bracket so that it is secure , then that is the problem. You may be able to find a replacement brachet in a home depot type store .
Please Vote !!
May 26, 2010 | Hunter 20436 Beacon Hill White Ceiling Fan
Cannot stop the ceiling fan from wobbling. Have
you still have a blade that is out of balance. mesure each blade from the bottom side end to the celing in one spot. Do this for each blade when you find the one that is closest to the celing then you have to place the wheight on the edge of that blade then spin it to make the right adjustment then seta stick on weight where the temp. weight is at
Jul 31, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Fan appears to be out of balance
There should have been a small lead weight kit that came with your fan. First check to make sure all the screws are on tight and clean the blades from any dust buildup. Make sure your blades aren't warped. If they are, you cannot balance your blades and will need to buy new ones. See if that helps. If you don't have the lead kit you may be able to buy one at your hardware store. You can also measure the end of the blades to the ceiling to see if one is warped or heavier than the others. You can also remove the blades to see if it's the actual motor assembly that is out of balance.
Jul 01, 2009 | Hunter 23258 The Paramount XP New Bronze...
Hampton bay ceiling fan
You can probably find outdoor blades at Home Depot, Lowes, etc.
There are ways to reduce the warping of indoor blades, but it's too much for most people. I'd suggest replacing them.
You could also surf the net for Hampton Bay stuff -- might be able to find them there, too.
May 28, 2009 | Hampton Bay 24002 Ceiling Fan
Need to replace socket in Hi hat ceiling fixture
Do you have a discription? In order to get to the main wires of a flush mount fan turn off power to fan, remove Lt kit if applicable, Take off blades. Does this sound right ?
Nov 13, 2008 | Electrical Supplies
This is actually a Delta II model fan. The fan blades and the ring they are bolted to recently dropped out of the fan housing and are sitting on top of the base of the light kit. Is this the flywheel? If...
it is the flywheel. I ordered one directly from the Casablanca web site, took the fan down and find the parts are pressed together. Looks like it needs some heavy tools or a jig of some kind. Any suggestions?
Jul 05, 2008 | Casablanca Fan 3245T Ceiling
Heating & Cooling Logo
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
