Question about Bunn BT10B Coffee Maker
Coffee is weak and watery
I use the same 5-6 scoops of coffee, but now when I pour water into the maker - it runs quickly and doesn't seem to brew the coffee at all. I get watery, weak coffee. I have run vinegar through the system and it is still doing the same thing. What can I do? Is it missing a part or something??? The flow of coffee out is very fast.
Thanks for your help.
  • Anonymous Mar 17, 2014
    coffee brews but is light in color like tea
  • 21 Answers
After reviewing troubleshooting diagrams, I really couldn't find a solution to your problem.
The only thing I can suggest is to use 2 oz per pot of coffee grounds. Your 5 or 6 scoops assuming they are one ounce each is way more than enough.
Look under where your basket goes. Most bunn coffee maker has a flavor guard on the downspout. this down spout actually helps distributes the water over the whole basket of coffee grounds. Most of the time I see these missing, and when they are gone, they are gone.
Use less water for the amount of coffee you are using first. Sadly when there is not enough water, the coffee tastes bitter. Too much water tastes weak. Hot water extracts certain elements out of the beans even after grinding.
Always use a fresh paperfilter designed for your coffee maker.
If this pot is not work correctly still, I will suggest seeing your appliance repair technician.
Posted on May 26, 2008
Making coffee. Lost my manual.
Step 1
Warm your cafeti?re using some hot tap water and let it sit for a minute before emptying it out. Add two dessertspoons or a level scoop of Bewley's fresh ground coffee per person
Step 2
Pour in water just off the boil (equivalent to one mug per person) and stir to release all those fabulous flavours. Leave for 3-5 minutes to brew.
Step 3
Slowly plunge your coffee by pushing down on the centre shaft until the metal filter gently reaches the bottom of your cafeti?re.
Step 4
Pour your coffee then add milk and/or sugar to taste.
Step 5
Sit back, sip and enjoy!
myLightSmile
Dec 14, 2015 | Cuisinart DCC-2200 14-Cup Coffee Maker
NEED TO KNOW HOW TO MAKE COFFEE.
Step 1
Step 2
Step 3
Step 4
Step 5
My tassimo coffee comes out watery
Make sure you push the lid down all the way before putting the clamp down on the front.
I've noticed that the back of the lid on my vivy (t12) can get stuck up (even with the clamp down) causing the water jet to not be inserted all the way - which produced very weak coffee.
May 14, 2012 | Braun Tassimo Coffee Maker
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 | Vacuums
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My Bunn Coffee maker has one solid stream of water running from the nozzle. It goes straight down through the filter. The coffee is weak. Isn't the nozzle suppose to spay? I thought about using a...
I work for BUNN. It sounds like your sprayhead is missing because it should definitely be spraying versus flowing. We will send you out a free sprayhead - please call our customer service department at 1800 - 352-2866 with your model and will send it right out to you.
Feb 01, 2010 | Bunn GR10 Coffee Maker
How to make coffee with the toastess coffee maker
If the scoop is 1 tablespoon, use two scoops of ground coffee for every six ounces of water you are brewing.
If the scoop is 2 tablespoons, use one scoop per six ounces.
Also be sure your grind is proper for the type of filter you are using.
Apr 01, 2009 | Toastess TFC-42T 2-Cup Coffee Maker
Coffee out of the machine seems too watery
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Feb 22, 2009 | Gaggia Syncrony Compact Coffee...
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Weak coffee
It sounds like you may have lost the sprayhead. It is under the brew basket (above the place where you put the basket with the filter and the coffee). Sometimes they get loose and you don't realize it and it can fall in the grounds and get tossed out after brewing.
Jun 13, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn BT10B Coffee Maker Logo
372 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
