Whirlpool dryer does not stop when open door, only when cycle ends. Help.
  • Washing Mach... Master
  • 3,361 Answers
The door switch is bad and has welded shut in the on position.
Replace the door switch.
Posted on Oct 02, 2010
    Brigadier General:
  • 4,088 Answers
Replace a defective door switch. Good luck!
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
My Kenmore dryer series 90 continues to rum when I open the dryer door?
If the dryer stops at the end of the cycle or when you turn the dial to off,
The door switch has gone bad.
If it does not stop at the end of the cycle the timer has gone bad.
Sep 06, 2010 | Kenmore Dryers
Machine thinks door is open and won't run a cycle!!!!!!!!!!!!!!!!
There is a catch latch on your dryer door and that may be softening up when the dryer gets warm and the clothes tumbling against the door is enough to push the door out to the point that it thinks it is open. Try this exersize... The next time you wash clothes place a chair sideways against the doon with your clothes basket on it and see it it completes the cycle If it does then your door latch and actuating arm / post need replaced.
Jan 13, 2010 | Dryers
When the dryer is hot and you open the door it smells like rubber burning
Your dryer is getting to hot due to the cycling thermostat being bad. Also check you vent for clogs. If you don't replace the cycling thermostat your thermal fuse will end up going bad. Then your dryer will stop heating. You will find the cycling thermostat on the element shoot. It's round, has two screws and two wires going to it.
Please rate solution
Sep 06, 2009 | Whirlpool Dryers
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Apr 13, 2008 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
