Question about Magic Chef Microwave Ovens
I have no power!! is there a fuse??? - Magic Chef Microwave Ovens
  • Magic Chef Master
  • 3,361 Answers
Yes.
Posted on Oct 02, 2010
I have kenmore mikewave over cook a meal, now no power, is there a fuse in them if so where, if so is there a no i can call to replace the fuse
My experience with another brand had the fuse inside the unit, which required taking the cover off. It was a glass cartridge fuse on the circuit board. This is a job for someone familiar with working with electrical devices.
Jan 01, 2015 | Kenmore Microwave Ovens
Got switched off suddenly and all panel lights got off
The main fuse is inside the cabinet near where the power cord enters. When everything goes dead all of a sudden, 99.9% of the time it's the fuse.
Apr 05, 2014 | KitchenAid KHMS2050SSS Microwave Oven
Has no power,
see the next steps: God bless your use the common sense, NOT feared.
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
see the block
Jul 31, 2012 | Amana ACO1520A Microwave Oven
Does not start. The power cord, plug, etc., are O.K.
Hello :
Maybe there's a problem with the power transformer or the power PCB [ Printed circuit board ] . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 29, 2010 | Emerson MW8625W Microwave Oven
No power. Checked AC connection and have power
Most microwave ovens come with a fuse. Typically it is a 20 Amp fuse. Be careful if you decide to open the cover, the the fuse should be close to the electrical wires coming from the plug. Hope this helps.
Jan 04, 2010 | Microwave Ovens
Does not turn on at all it's totally dead
It may be a fuse or, the power supply board. you can check the fuse by removing the cover. the (IN-LINE) fuse is located on the power supply board. check it for continuity. if the fuse is in good condition, replace the power board.
Jun 03, 2009 | GE JVM1631 Microwave Oven
No power on the microwave
HI, there is an in line fuse located on the Ac power cord near the power supply inside the microwave. Check to see if the fuse is blown. replace the fuse if needed. Now, if the fuse is in good condition, this will confirm power board failure. you will need to replace the failed component or replace the entire power assembly in this case.
May 30, 2009 | Panasonic Microwave Ovens
Power off
Chances are if there is power available to the unit and it will not power up, the internal fuse has opened. This is not a user serviceable type repair. that being said, remove the cover, near the power supply is a ceramic fuse, test/replace the fuse reassemble. if the fuse continues to blow it will most likely be easier to replace the unit than to repair it
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has no power
Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
- Jim
Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
No power
You mentioned taking the "buttons" off. That may not give you complete access to the units motherboard or power supply area. Unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Jan 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
