Question about Craftsman Garden
3.5 TECUMSEH ENGINE CRAFTSMAN LAWN MOWER. STORED LONG TIME. WOULD NOT START-CLEANED FUEL SYSTEM -GOT FRESH GAS. LAWN MOWER STARTED-HAS A HIGH IDLE NOW AND WILL NOW IDLE AT NORMAL IDEL SPEED. HOW TO CORRECXT IDLE
  • 333 Answers
Float stuck in open position. When the gas evaporated in it there was a gunk left behind and then It was down and either froze up or there is trash keeping the needle valve from sealing up all the way.
So when you start it gas keeps pouring into the motor. It is suposed to shut off once it gets enough to run on.
Be real careful take the carb off and remove the bowl. And then the float. Take a q-tip and clean the needle valve port ou real good. And clean the rubber tip gently. Then put back together.
When it is upside down the float should be parallel with the carb. That would be the shut off point. You may have to adjust it.
That should do it. When you hook the gas line back up loosen the bowl and let gas in carb til it starts to run out. Then mow.
Posted on Oct 02, 2010
Lawnmowers; mine is not starting. First use this year I believe the fuel might be gummed up from sitting over winter. How do I clean this out?
When gasoline sits for an extended period of time the "varnish" builds up inside the carburetor and can keep your engine from running. If you suspect that this has happened, the only good solution is to first replace the carburetor, and then ALWAYS use a Fuel Stabilizer every time you buy gas for your lawn mower.
Also, at the end of a season, it is always a good idea to run the engine until it is dry and out of gas before storing the lawn mower over the winter. A fuel stabilizer should keep your gas fresh over the winter, and the lawn mower will start up quickly in the spring. If you are the cautious type, always buy fresh gas at the beginning of every season, and NEVER forget the fuel stabilizer no matter what. Gas starts turning bad after just 30 days....
Rayko
May 23, 2015 | Garden
16.5HP Honda engine wont run
An engine needs fuel air and spark to run. Is the air filter clean. Use a "spark checker" to see if you have spark. They are not expensive and available at stores that sell lawn mower parts. Is the spark plug clean? If it is not clean it with a wire brush.Squirt some starting fluid into the carb. If it fires your gas has gone bad or it is not getting gas. If it has sat a while gas does go bad so drain the fule tank and out in fresh gas.
Sep 05, 2013 | Craftsman Lawn Tractor Operators Manual...
Sears Craftsman mower 17hp Briggs & Stratton engine. Replaced starter, spark plug and fuel filter. Will not turn over unless jump started. When running has no power.
Charge battery to 12.8 volts or higher. 13.2 best. Below 12.8 volts replace battery. USE FRESH GAS ONLY. Always use Stabile in gas. Ensure oil is full. 30w. Clean or replace air filter.
Aug 03, 2013 | Craftsman Garden
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
I changed oil, blade, spark plug,air filter on tecumseh lawn boy 10685 mower...now it will not start!!! gas tank was emptied, per instructions. before changes, it started right up on first pull before...
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Aug 04, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
My craftsman lawn mower stalls .i changed the oil and fresh gas..air filter is clean
check the magnito there may be build up of rust on it.
it could also be a bad sparkplug
Jul 29, 2009 | Garden
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
295 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
