Question about LG 42LC2D 42 in. LCD HDTV
The bottom of my tv does not wanna come out, because i feel it needs to be adjusted cause its kinda of to loose and kinda leaning forward could you give me a hand?
  • 11,361 Answers
I need to now how to set front caster camber on 2.3i 1996 VW Combi
Castor and camber are two separate adjustments.
Castor is how far the suspension strut leans forward or backwards and adjustment is very limited.
Camber is the tilt of the wheels top to bottom measured across the car. How far apart are the wheels at the top compared to the distance at the bottom. Adjustment depends on the suspension fitted. Like castor, camber adjustment can be limited. So work out which one it is you to adjust.
Feb 09, 2018 | Volkswagen Cars & Trucks
Indsit washingmachine: making scraping noise when spinning. metal drum inside feels loose and is leaning forward making it scrape on whatever is underneath. how do i stop the drum doing this?
If the inner drum is loose the bearing may have failed or the drum shaft spider may have broken. the scrapping will be the drum hitting the heating element.
Dec 30, 2012 | Washing Machines
Over heating and sputtering
kohler engine air cool they will over heat if fuel system lean carburetor clogged out of adjustment causing lean fuel mixture,air cool engine need plenty air to keep cool, make sure air filter clean and make sure cooling fins not clogged with debris make sure shrouds and blower housing are tight so air can circulate. air cooling engines kinda remind you of 1963 corvairs
Sep 09, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kitchen aid mixer leans forward too far, causing the mixing attachments to rub on the bottom of the bowl instead of rotating just above the bottom of the bowl. how do i fix it?
Is this for a "tilt neck model? If so, the manual suggests that there is a small screw in between the base stand and the "neck" of the mixer. You should be able to screw it in or out to adjust it. Good luck!
Oct 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Winchester WL-7350WR 7X35 binos out of aligngment/colimation- need to re-adjust. Don't know if there's any objective lens alignment method, but I have found the rear adjusting screws for the prisms under...
There are another set of adjusting grub screws not just these! If you need to collimate them then you will need to adjust the correct ones to avoid what is known as "conditional collimation" where they are only good for people with the same IPD (interpupilary distance). If you feel confident that you can do this fine. But first is there any leaning field obvious? Using one side at a time and looking at a horizontal or vertical object (like a flagpole) show any lean when compared to the visual appearance? If it does then you need to send them to a service centre for correct alignment.
Feb 23, 2010 | Winchester Optics
I have an echo chainsaw cs 346 it starts fine revs fine but chokes out when under load if i faether the throttle kinda helps cleaned the carb no different any suggestions
Try rotating the "H" adjustment CCW a small amount.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Jan 07, 2010 | Echo Garden
Our GE upright freezer door keeps opening on its own! Our food is starting to melt and the manual only talks about tightening the refrigerator door. What should i do?
Your refrigerator is leaning forward to far and you need to adjust the front legs so that it is slightly leaning back. This is why the doors are opening as they work by gravity. On the bottom left and right front corners of your refrigerator you should round pads with threaded legs screwed it the bottom of your refrigerator. You need to lean the unit back and adjust these out to raise the front of your refrigerator until the doors when opened will slowly shut on its own. A level comes in handy for leveling also.
Oct 09, 2009 | GE Refrigerators
Hydrostatic cooling fan belt adjustment
If the belt is loose it may simply be worn out and need to be replaced. Look carefully to be sure that the belt didn't come off one of the pulley wheels as this might give it the appearance of being loose.
The way the belt tightener is engineered, there is no tightening to it, just spring tension. Get back and let me know where it is at. I know I can assist you in gettting to the bottom of this problem.
May 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
When i hit a jump or hammer a turn my back foot binding pops open I have tried to adjust the tension"
It sounds like when you are hitting a jump, and carvin into the turn you are leaning way forward, causing the tension on your cables to release and allow it to "pop" open. I'd say try to adjust you forward lean.
Mar 02, 2009 | Flow Amp 5 Snowboard Binding
Off idle hesitation and trottle response
You need to set the valve clearance and the cam chain. After that try setting the fuel air mixture screw. Your bike is running lean off the bottom thats what's causing the weakness at lower rpms. My suggestion is to first adjust the tight valves and then the carb. The valves cause all sorts of issues.
Let me know if this does not work and I'll give you more solutions.
Dec 02, 2008 | 1989 Honda XL 600 V Transalp
LG 42LC2D 42 in. LCD HDTV Logo
50 people viewed this question
Computer Repairing
Computer Repairing
