Question about RC Thomas the Tank Engine
My thomas the train ride on toy wont move unless you assist it by turning the wheel after pressing the go button
    Problem Solver:
  • 17 Answers
A few things can cause this: The battery is weak/bad. The connector at the battery might be worn out and have intermittent contact. Those are fairly easy things to check. Next, the GO button might be worn out internally (high resistance contacts)-believe it or not, the whole motor current goes through that switch. You would need to remove top of the roof to access the button. Or, open the speaker cover, pull out the control board and bypass Go switch wires to check for train proper operation. As you are already there, inspect the control/sound board. The last thing that comes to my mind is the motor itself, it is under the seat. Check contacts to motor, plus you can spray contact cleaner or, if you don't have anything else, alcohol. Avoid using WD40 - it does the job, but collects new dirt very very fast). There is always a chance of pinched/loose wire, or mechanical problem with gear assembly/jamming or so.
Posted on Sep 04, 2012
I got a thomas ride on new without the instructions. I can't get the light to work when I tapped it it went on once for a short second. Does ayone know how to solve this problem or how to get an instruction book?
Posted on Dec 28, 2010
How do I change the battery in a motorized wooden railway engin for thomas the train
2 options.
1.if its the kind that fits on the wooden track look for a screw (philips/star screwdriver) on the underside of Thomas near his face. The body shell should lift off.you will then see the battery.
2 If it's the plastic blue track you have to squeeze the right center wheel and left center wheel. Thomas has 6 wheels so the 2 center/middle wheels, after squeezing this will then make the top portion pop off.
Jan 10, 2011 | Thomas and Friends Battery Operated Train...
I have the Thomas and Friends Trackmaster talking Thomas train. 2 days after I bought it he stopped working. I changed the batteries and now he only talks. He wont move on or off the track at all?
I brought one a few days ago and out of the box it talked but would not move. I returned it to the store for a replacement. I noticed that the back wheels under the on and off switch have weight on them before the train will move. If the train is not sitting on the track, it will not move, That is what makes thomas stop at the station
Nov 11, 2010 | Thomas and Friends Trackmaster Motorized...
Thomas train peg perego instructions
have to hold on the button that has arrow untill it moves
Apr 03, 2010 | Peg Perego Ride On Santa Fe Train
Thomas the Train Ride on Train only goes backwards
Check the battery. It sounds like you have it in, backwards.
Sep 17, 2009 | Toys
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Dec 16, 2008 | Peg Perego Vespa Scooter
Ride on thomas peg-perego
Sometimes the battery and/or the charger can go bad. If the battery is less than 6 volts on a multimeter, it won't operate for long. Is the headlight bright or dim? Remember that the button has to be held down to run. Releasing the button will stop the train.
If neither of the above works, you may want to order a new circuit board from tigerimports.com.
Jul 29, 2008 | Toys
RC Thomas the Tank Engine Logo
1,565 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
