Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
The brush on my hoover windtunnel stopped rotating.We already replaced the belt, and that did not seem to help
  • 377 Answers
Check to see if the brush is frozen up. If you can not rotate it by hand you need to remove it and clean as best you can. Add a bit of WD40 at each end by the pieces that hold it onto the vacuum and turn by hand to be sure it is free. When reassembling, make sure the belt is put on so that the brush turns in the proper direction.
Posted on Oct 02, 2010
It seems when i am vacuuming it is very hard it move and the brushes does not rotate after the rug strings got into it.
Your belt is stretched or worn and therefore cannot turn against the resistance of the carpet. If you replace the belt it will fix the problem. You can get the belt you need here:
http://www.vacbelts.com/hoover-windtunnel-belt-.htm
Oct 24, 2009 | Hoover U6630-900 WindTunnel Bagless...
I have a Hoover Windtunnel U 6439-900. The agitator brush will not turn. I installed 2 new belts, # 38528034, and # 38528-035 There is so much slack in belt # 3852034 (brush drive) that it cannot grip the...
There is an idler pulley that takes up the slack in the V belt when you pull the handle back to vacuum. Make sure it is engaging properly and the V belt is installed correctly.
Sep 09, 2017 | Hoover U6630-900 WindTunnel Bagless...
Brush roller does not turn off in upright position
make sure there is not a lever to move in order to stop the brushes/agitator...
if the belt makes contact with the end of the shaft the brushes will rotate...
tighten all of course/and take the panel of to check behind the bag to make sure all is tight. (fasteners)
take off the face plate to make sure that the adjustment for the floor tools is not broke and belt is ok.
Sep 13, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Brush won't spin when position of handle changes
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
213 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
