Question about GE Profile PDW8000G Built-in Dishwasher
Our GE DIshwasher PDW8000 Series - the Coil got heated and melted the plastic fan at the bottom. Although dish washer was empty at that time and was not running.
    Problem Solver:
  • 17 Answers
Just call me on +263912639492, thta's easy.thank you.
Dr. Kelson
Posted on Oct 02, 2010
My PDW9280LOSS GE Profile dishwasher runs and cleans fine. However, after my wife had unloaded the dishes and closed the door she notice sometime later that the the dishwasher got very hot, hot enough to...
Sorry Bill Bridges... Nice machine.
They don't call it the
"TERRIBLE TWOs" for nothing...
You have a (brilliant/inquisitive) developing mind...
learning , physics, language(s)... acrobatics... potty & how to "HANDLE" adults (psychology... etc.).
Once an appliance falls prey... I'm not sure
speculation would be all that productive..
Normal operation that should not occur...
"ADDED HEAT" is discussed on
page 14 of your owners manual (see below).
GE PDW9200 Technical Service Manual Demo Mode Heating Element
"CHILD LOCK" is discussed on
page 7 of your owners manual (see below).
GE PDW9200 Technical Service Manual Page 7
> An important part would be are PARTS AVAILABLE
http://www.appliancepartspros.com/search.aspx?model=pdw9280loss
Also look at REPAIRCLINIC.com ... PARTSELECT.com
(even SEARS... if you must)
>> Most important... keep the child safe with that LOCK.
May 04, 2017 | GE 24 in. PDW9280LSS Built-in Dishwasher
When in use, my dishwasher at times, makes a lot of repeating noise and it appears to tick.. th digital reading on the right blinks CL CL CL CL then HOT then goes back to tell you the remaining time, and...
Some dishwasher noises are normal, like the hiss of water rushing through the water inlet fill valve, or the hum of the pump motor, or the slosh of water. But if your dishwasher is making strange sounds or is unusually loud, it's time to investigate. A thumping noise could be the drain line vibrating against the cabinet; a grinding noise could be caused by a popcorn kernel being stuck in the chopper blade area of the dishwasher.
The CL is normally indicated child lock has been activated.
Dishes typically dry by the end of the dishwashing cycle, with one exception-plastic items. Because plastic doesn't retain heat like glass, ceramic and metal do, you'll almost always see drops of water on plastic items after the cycle finishes. Rinse aid helps water drain off all dishes so they dry better. Make sure that you fill that rinse aid dispenser when it's empty. A heated dry setting also is an option to enhance drying. You may have this option turned off to save energy, but if your dishes aren't drying as well as you'd like them to, you might want to consider turning it back on. Consult your owner's manual and select the cycle options that fit your needs and your energy usage goals. If your dishes don't get dry even though you've selected the heated drying option, then the heating element could be broken or the high-limit thermostat for the element may have tripped in error, preventing the element from heating. A malfunctioning vent or drying fan could also prevent dishes from drying. Check out this troubleshooting video that could help you correct a drying problem: Dishwasher Not Drying Dishes Video.
Oct 26, 2017 | Frigidaire FDB1502RGS Built-in Dishwasher
Hello I have a Quiet Power 3 dishwasher that is leaving food residue on my dishes. The dishwasher is 2.5 years old and all of a sudden this problem is happening. I have not changed dishwasher soap. It...
If you live in a area with hard water, there may be a large buildup of hard water/soap scum in the bottom water reservoir where the pump, filter, and other working parts are. This is located inside the tub, not underneath. This scum/crystallized material can clog the water channels & filter so the water jets don't spray hard enough, as well as overwhelm the filter. Because phosphates were ordered removed from dishwasher detergents, hard water minerals can now react with the soap to create a heavy greasy-feeling scum. That scum can build up in the water lines, arms, bottom reservoir, and filter, providing an endless supply of goo to spray on your dishes. This can be fixed. You need to remove and clean out the spray arms, the filters, and especially the array of parts at the bottom of the tub. I've seen up to 1 cup of coagulated/crystallized scum in the bottom of dishwasher tubs (I know this may be beyond many homeowners, so if you aren't up to this first step, then just try the next/second step but do it 3 times with no dishes in the washer). Once you clean out the scum, then run the washer empty with a completely full detergent cup on the highest temperature setting, extra rinse. Before you start it add to the detergent cup 1 teaspoon of TSP(tri-sodium phosphate), a very powerful phosphate cleaner available at hardware stores. Your washer will now have all scum gone from the inner workings. From now on you must always fill both your detergent and pre-wash cups to the max and use a high temperature water setting, extra rinse. Chemically what you're trying to do is adding so much detergent that the scum-forming reaction is overwhelmed by the dispersant action of the detergent, and the extra heat helps this to be more effective. I am not a fan of vinegar in the wash cycle. Why? In some washers the vinegar fumes can reach the exposed contacts of the printed circuit board or touch pad, corrode them, and then your washer won't work at all, along with being very expensive to fix.
Nov 15, 2010 | GE Dishwashers
Is there a heated dry feature on the Dacor? When I open the door at the end of the cycle there is still a lot of moisture and water droplets in the unit.
Below is a website with information about your dishwasher. It says it has a condensation dryer which means it dries the dishes using the heater coil in the bottom of the unit. This is a very slow process which continues to dry even after the unit has run all of its cycles. Usually over night they should be dry but any puddling water left on the dishes such as an over turned mug or cup will still be left on the dishes. The drying is done in this way to prevent damage to delicate glassware or melting plastic items in the unit. There is no dishwasher available that can fully dry the dishes due to the possibility of damaging your dishes.
http://www.homeeverything.com/web/sitefiles/product-9166/ED24.html
Sep 28, 2010 | Dacor ED24 Built-in Dishwasher
Dish washer gets to hot in pot scrubber mode
did it distort the spray arm? A lot of times if it's the spray arm that melted it's possible that it was jammed while trying to heat the water and the heat from the element would warp it.
Mar 24, 2010 | Frigidaire PLD4375RFC Dishwasher
GE Profile Dishwasher not cleaning - older PDW7880GOOSS
My GE Profile Dishwasher PDW8280N00SS wouldn't clean the dishes. I found what looked like plastic particles along with food particles in the wash arm spray holes. I found that heat had warped the gray flat filter in the bottom allowing food particles to bypass the filter, and I found that the flexible plastic sump inlet was disintegrating internally shedding plastic which clogged the filter to the pump and getting into the pump. This shouldn't happen. The material that the sump inlet is made out of is too soft and porous. I noticed other components in the wash water system made from the same white flexible rubber which is an unacceptable material. I bought replacement parts at a cost of $100 for both and this has solved the problem. What's distressing is that the replacement parts appear to be made of the same inferior plastic. And I have noticed upon closer inspection that additional interior parts appear to be heat damaged (warped). This dishwasher has been used less than 4 years and problems like these in a high end dishwasher are unacceptable.
Sep 15, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Whirpool dishwasher
Ours does the same thing. I have been suspicious that it is the melting plastic stuff used in the dishwasher tabs that the wife uses.
Let me know if you use that same tab to wash you dishes.
We dont have any problem with the stuff getting on dishes (and we use all white diner type dishes.).
Jan 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Melted utensil on heating element
Hi amsaunders5,
I'm Harvey the Master Plumber.
Your problem is: Children tried to surprise you by doing dishes. The plastic spatula melted and stuck on the heating coil on the bottom
This is a common problem. First, thank the children, it really wasn't their fault.
It's going to take some effort but you'll have to scrape/remove the plstic from the element. Replaceing the element is not a repair I recomend for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
GE PDW9700 - Heating Element turns on by itself and Burns my dishes
have experienced this problem on some zanussi machines. what is happening is that the machine continues thro cycle thinking there is water in machine when there is not. can be caused by:
slow pump rate caused by blockage especially near the drain pump inlet
faulty pressure stat
Aug 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE Profile PDW8000G Built-in Dishwasher Logo
148 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
