Question about Home
HOW TO ADJUST THE WATER TEMP ON MY WATER HEATER
  • 37 Answers
The cover on side of hot water heater comes off with screwdriver the adjustment knob is behind that cover
Posted on Oct 02, 2010
How do i adjust water temperature
Start by turning breaker off to water heater,then remove both hi & lo panels there you will see tstats, with a screwdriver adjust to desired temp. 2 tstats 1for each heating element
Jan 15, 2015 | Water Water Heaters
How do set the temp on a 15 gallon tank
leave the heater unplugged in the aquarium in for several hours.Then plug it in briefly and see if the neon bulb lights up (sort of an orange color). If it is on, turn the temp set knob counter clockwise until it goes out. Then turn the knob clockwise slowly until the light comes on again. Now your heater is set for approximately the current temp of the aquarium water. Now adjust the knob in very small increments, waiting hours between adjustments until the water is at the temp you want.
Jul 29, 2014 | Fluval Hagen M50 Submersible Aquarium...
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
I just had the elements replace but my water is not getting hot. How do I turn the temp up on the water heater
To adjust water heater temperature:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Electric water heater is fully repairable by homeowner with a few basic tools.
If temperature setting is not the problem:
Buy $10 multi-meter from home center and take 30 minutes and do complete troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
For example if you replaced elements, but didn't clean sediment out of tank, then the root cause was not repaired by element replacement.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on heater.
Jan 08, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How do i adjust the water tempature from the hot taps ?
you don't adjust hot water temp from the taps...
you can only adjust from the water heater.
what water heater do you have?
Aug 14, 2010 | Water Heaters
How can I adjust the shower knob to produce hotter water then it does now. It used to be hotter. Taking the knob off reveals a white piece of plastic with a colder to hotter temp. gauge. How can I adjust...
Should be able to adjust clockwise or counter clockwise to adjust the temp. You said that the temp used to be hotter. Check the temp setting on your water heater. Did you replace your old water heater? Hope this helps.
Mar 07, 2010 | Home
Water temp
The water heater thermostat control is usually under a plate/cover toward the bottom of the water heater. Remove the cover (first turn off the power to the water heater) and look for a dial with temperatures marked on it.
You can adjust the thermostat using its knob (if it has one) or a screwdriver. There may be insulation covering the thermostat, so you may have to pull some of that out of the way to see the thermostat.
Apr 29, 2009 | Water Heaters
Hatco c 12
hi my name is mark. hi limit safety has a red reset button follow link to instructions to adjust rinse temp to dishmachine. i hope you are not using this unit as a home water heater. http://www.hatcocorp.com/productinfo.nsf/AllDocumentationAttachments/14B2C666CC6F114286257107005AC28E/$File/EBOOSTERM-0406.pdf?OpenElement
Feb 09, 2009 | Hatco Corporation Compact Electric Booster...
Home Logo
55 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
