Question about Honeywell CT3500 5-1-1 Day Electronic Programmable Thermostat Heater
I have a Honeywell CT3500 Thermostat and would like to know how to reset the unit to factory settings. I have pulled the batteries, or unplugged the unit from the wall for up to 30 minutes, but to no avail.
Therinnaiguy
  • 1420 Answers
SOURCE: honeywell thermostat
Go to www.honeywell.com and search their data base for your model of thermostat. You wil need all the numbers of your thermostat to be able to search. Once you find it, download the installation manual.
Good Luck.
Posted on Dec 03, 2007
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
billyvangogh
  • 108 Answers
SOURCE: Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Posted on Oct 31, 2009
  • 33 Answers
SOURCE: How do I reset my honeywell hz709?
here is a link to the owner's manual for that model, it has reset procedures listed. http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
Posted on Jan 08, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a Honeywell CT3500 Thermostat, nd the
Press hold button continuously for 5 seconds.
Posted on Dec 03, 2010
Honeywell th6320r1004 thermostat is stuck in connect wireless mode. Eig unit not reading thermostat and fan is stuck on. Cant exit set up wireless mode and hard reset wont work. Help please?
How exactly did u preform the hard reset ??? U do know that u need to remove both the batteries and remove power to your heater (its connected too) for like one minute or more to properly preform a hard reset >
Dec 16, 2016 | Heating & Cooling
Need manual for Honeywell thermostat ct3500
Here you go Carol.
Honeywell CT3500 Owner Manual
Have a great day!
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Jan 20, 2014 | Honeywell CT3500 5-1-1 Day Electronic...
Need a manual
Hi Carol.
We have a Honeywell Digital thermosat. We just put brand new batteries in it and it is still showing lo battery.
on most of honeywell units if you pull the face of the thermostat off there is a reset button you can puch and reset try this.... if it does not have a reset remove the red power wire on the "r" terminal and if you have a wire hooked to the "c" terminal remove it at same time ///take batteries out prior to doing this and it will reset the program in thermostat... if the display comes back again with the lo battery the thermostat internally has a issue...good luck
Jan 09, 2011 | Honeywell Programmable Thermostat Heater
Is there a temp differencial setting on these thermostats
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jun 17, 2010 | Honeywell CT3500 5-1-1 Day Electronic...
I replaced the batteries in my Honeywell CT3300 and the "Bat Lo" message won't go away even with fresh batteries. Is there a reset button or something?
Per manual do this: System set to Off Remove batterie Replace IN REVERSE POLARITY POSITION or 5-10 seconds Put back in with CORRECT POLARITY Reprogram per sticker on back of thermostat. Done. Just did this myself and it's simple and effective! PaulHaven
Oct 14, 2009 | Honeywell CT3200 5-2 Day Electronic...
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell Chronotherm IV Plus requires frequent resetting.
Check to see if you have wires going to a C/C1 terminal. The older chronotherms used a transformer to supply 24 volts to power the clock. If in fact you do have these terminals, then I would suggest checking the output voltage on the transformer, (secondary (24v)side) to ensure it isn't close to dead. Hope this helps
Nov 28, 2008 | Honeywell Programmable Thermostat Heater
Battery backup?
which model do you have ? the 8000/8001 or 8011 the set is different depending on your type of heating system. This model has a memory chip not a battery that saves your settings. So you could be looking at replacing the unit.
Jan 05, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
87 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
