Question about Timex Expedition 40141 Wristwatch
How do you get the stem out? - Timex Expedition 40141 Wristwatch
  • 2,334 Answers
There is a small hole next to the stem insertion point on the movement (or groove) where you can see the tiny piece of metal. This is setting lever and it holds stem in place. Take fine pointed tweezers and push and hold on it (in hole or in the groove). Stem will come out while setting lever is pushed down only. In some watches setting lever is fixed by screw,so, you have to unscrew it and then withdraw stem.
Posted on Jan 27, 2011
Where do you look for release of. The Stem if there is no small screw
There is a couple of different methods to release the stem,
1. By a screw, note if a screw only 1.5 turns only
2. push button near the stem, push button in and release the stem
3. pull the stem out and a little lever will be seen by the stem, press that and the stem will come out
4. if quartz, will have a hole with a small arrow pointing to it, with a needle insert into the hole to press the lever inside.
Otherwise need more information on the type of watch movement
Nov 29, 2017 | The Watches
I want to remove the stem from a Miyota 2015 Movement and insert a shotened version.
Hello Malcolm,
You can view the details with diagrams on how to remove the stem from this link:
Stem Removal (screw type)
Stem Removal (Push Button Type)
For the complete guide, you can refer to this link:
Changing Watch Movement / Stem
Oct 21, 2011 | Watches
How to set a month on seiko ska401
mcdevito75 here, The month you mean the date (number of the day in the month) your Seiko should show the day / date Here"s how.--- To change the day (Monday, Tues. etc) simply pull out the stem and turn the hands around until you reach the day, now push the stem in all the way, and gently slip your fingernail under the stem and gently lift the stem to it"s first notch or position, Seiko watches have a 2 position stem to make changeing the date, (number) easy so you don"t have to keep turning the hands around and around, with the stem out to it"s first notch or position simply turn the stem either toward you or away to change the date, (number) when done push the stem back in and your done.
Jun 23, 2010 | Watches
I need to fix the date on my breil tw0287. how can i do this?
mcdevit75 here, If your watch has a stem (winder) simply place your fingernail under the stem and gently lift the stem to it"s first notch (position) now you should be able to turn the stem (winder) to change the date push the stem back in when date is set.
Jun 23, 2010 | Briel Breil Globe BW0213 Watch for Men
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
I have a problem pulling out the stem to set the date on my Roadster. Can you help? I can't seem to grasp the stem securely enough to pull it out. Thank you
mcdevito 75 here, you should be able to get a finger nail just under the stem to lift the stem to set the time, day/date, first be sure the stem isn"t a screwdown type, gasp the stem and turn it to see, if it is a screwdown type, simply un-screw the stem then pull it out to set the time, day/date. If all fails your local or any jeweler can help.
Jun 16, 2010 | Cartier Roadster W62016V3 Wrist Watch
How to change the time on Bulova Marine Star 100m. This is an old watch with 4 stems. 2 on each side. One is an on/off stem which is on the right side of the face.
1st: make sure the watch is set to "tme" , the botton dail display, press bottom right stem
2nd: pull out the bottom right stem ,
3rd: press the left top stem for increase time . i.e. 2:40 pm to... 2: 45pm
4th, or press the left bottom stem for decrease time: i.e. 2:40pm to .. 2:30 pm
5th: once time is good, then press in the right bottom stem,
May 03, 2010 | Bulova Marine Star 100 Meter Stainless...
I pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Mar 24, 2009 | Watches
Broken stem off aromen gobletover 50yrs old maker bleirristall made in bavaria.germany 24% clear stem any chance of repair have broken pieces was my Mothers passed away meens the world to me please help...
Is the stem broken near the crown? Or do you think there is enough stem to take out of crown? If not you probibly will have to go to a watchmake (NOT a watch repairman) to make you the stem. If there is enough metal to take stem out of the crown you may be able to get someone to solder the stem back together. I do that reguarly with stems that are vintage, and I don't want have the time to remake the whole stem. Let me know. Good Luck!!!!
Jul 09, 2008 | Watches
Illinois pocket watch stem removal.
First you must say what type as there are differences depending on the mfg and model.Be the following basics apply.
1- Put the stem in the setting position (usually pulled out if stem set).
2 Them open cover to expose the movement. ( Screw off or snap open).
3- Remove the movement (Usually held in place with 2 screws at the outer edge.
4-Then if there is a screw in the part that holds the stem loosen that.
5- The stem can be held with a pair of pliers on the flat and the crown unscrewed. Be careful not to damage the square (FLATS), with the pliers. A rag or other safety measure should be taken.
6- then inside the stem hole, looking from the ouside the is an annular area around the stem that has a ferrule screwed into the case this has to be unscrewed and will bring out the stem and the ferrule.
This siounds complicated but the steps are more involved to write than they are to perform.
There are many variations to this process, and each type should be understood before proceeding.
mrmel.mrmel@gmail.com
Dec 15, 2007 | Watches
Timex Expedition 40141 Wristwatch Logo
336 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
