Question about Marshall MG100HDFX 100-Watt Amplifier Head
The fan on the back of my marshall mg 100HDFX is making a weird noise when i first turn it on. It eventually sounds normal after about three minutes. Im not sure what i need to do?
You can either oil it up OR replace it for around 20$
Both ways involve removing the amp from the casing by unscrewing the 6 screws on top and sliding it out and then getting the fan out
locate the fan; locate the 4 outside screw covers that are next to the fan grill screws and pop them open. Remove the four screws that are under those plastic covers. The fan should separate. Take Fan out and remember how it was in there.
To oil: lift the sticker and locate the rubber plunger in the middle of the fan; remove it. Then, put ONE drop of regular 3-1oil NOT-wd-40, pb blaster or bike lube. re-assemble
To replace: just unplug old fan and then replace with new fan. I recommend replacing the fan when it gets to the point of bearing noise because oil doesn't always fix this.
Posted on Oct 06, 2010
I have an MG 100hdfx everything works fine till I plug in foot-switch, nothing happens when stepping on either switch. I've lifted the front of the head to about a 45' angle and the foot-switch activates...
it sounds like something internal on the foot switch is shorting out (or a lead wire has come off) or some where in that line , it has been severed. you can check continuity with an ohm meter. butfirst open the foot switch and just give it a visual to see if any leads are severed. you may just need to solder it back. - foot pedals get alot of winding up and unwinding. its common for something to disconnect. that would explain all the issues your having. good luck
Mar 30, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
My Marshall MG 50 DFX has a noisy fan. Can I take it apart and give a shot of oil?
Bo, the fans cannot be lubricated. If the noise is from bearings, replacement is the only option.
Dec 05, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall MB4410 - Dies and comes back to life every few minutes..
Our bassplayer had the same problem with his mb4410. As it turned out, the fan was not working when the amp got hot. It did turn when cold - go figure! Swap the fan for a good quality (Pabst, Sunon) 80mm pc fan with 2-wire connection. Three or four wire fans will not work w/out modding. See your local pc guy and ask for an unregulated, silent 24/7 fans. He will know. Our bassplayer sold the P.O.S. while still in warranty. HTH.
Apr 26, 2010 | Marshall MB4410 Bass Combo Amplifier
Buzzing fan on a Marshall mg 100 head
Try to remove the fan and look for the sticker on the back side where the wires come out.
Remove the sticker, underneath it there will be a small aluminium cap (sometimes there is no cap and the axis is readily visible when you remove the sticker).
Take the cap off with a sharp tool (it shouldn't require a lot of force to do it), now you should be able to see the fan axis being held in place by a small clamp - put a drop or two of machine oil in there, move the fan blades a little to make the oil flow past the axis into the bearing.
Reinstall the cap, put the sticker back in place, reinstall the fan and test it.
Sometimes this will make things better, but if it doesn't then it is only fair to replace the fan.
regards
Triarcuate
Sep 25, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall mg 100hdfx fan
Some of the Marshall equipment uses computer size fans and even on occasion the same connection.
Take the bad fan with you to a computer repair shop it will be much cheaper than a marshall part they should be able to help you out
Sep 09, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Feedback noise when overdrive is on
it could be your guitar pickups. try using another guitar or getting your pickups waxed at your local music store. also if your playing in a small room kind of loud, or if your using single coil pickups (like fender statocaster pickups) you will definitely get a feedback noise. if that does not work let me know.
May 10, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall MG100HDFX 100-Watt Amplifier Head Logo
643 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
