Question about Panasonic KX TCD715 Cordless Phone
Handset does not communicate with base.
I am unable to re-register the handset to its base. Please help. Thanks.
  • pucchi Jun 15, 2008
    i cannot re register my handset to the base. the information about the base in the handset is lost. the model no of my phone is KX-TCD705BX
Http://www.kmeuk.co.uk/customerservicesite/Manuals/705/705BXvZA.pdf
Refer to the manual at above location, goto the chapter about registring your handset with Base on page 42. Follow the instructions given and you will be able to reconnect the handset to the base.
Posted on Dec 18, 2008
Ive changed the batteries but need to re-registar the handset with base. any ideas ?
Thanks for visiting FixYa!
Without the specific make and model number of your phone I'm unable to provide you with the exact instructions to register your handset.
However, most handsets can be easily registered by turning them on and placing them on the base for one (1) minute.
If this doesn't work, please re-post this question and include your exact phone make and model number.
Apr 05, 2011 | Lands Phones
I bought a used handset for my Panasonic wireless phone system, and now it is still registered to the original base and won't communicate with my base unit. Handset is KX-TGA931T and base is KX-TG9331T. ...
They are correct - the phones are married to the original base and can only communicate with that unit since they share frequencies. Other handsets have different frequencies ans will not work
Sep 20, 2017 | Panasonic KXTGA931T Cordless Expansion...
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
Handheld won't communicate with the base
i have the same problem and it has happened infrequently several times. you probably have to deregister the handset and re-register it and rest the base and handheld to communicate since my model is different from yours there may be differences in how to go about it but for my model the suggestion is as follows:
go to www.uniden.com for customer support here is a direct link to some frequentlt asked questions http://www.mycusthelp.com/uniden/supportfaq.asp?sSessionID=&lstFilter_a=&lstFilter_b=&lstFilter_c=&txtCriteria=hanset+won%27t+connect+to+base&optcond=2&iStartCount=1
DCT Series Multi Handset Phone - reset to have base and handsets communicate
Question:
I have a DCT Series Multi Handset phone and one or more of the handsets is not working, what should I do?
Answer:
Try resetting the phone system by using the following steps:
1) Enter the "System Reset" menu, then "Deregister HS" submenu.
2) Press volume/up or down arrow keys to select the handset ID to be de-registered from the list, then press the OK soft key.
3) Press the OK soft key. You will hear a confirmation tone. When de-registration is complete, "Deregistration Complete" appears.
4) After de-registering the handset, move to "Replacing the Base Setting" below. When you go through the deregister procedure if you get "out of range", That is okay. Go ahead and go to the next step.
1) Enter the "System Reset" menu, then "Replacing Base" submenu. "Do you want to replace Base?" appears.
2) Press the OK soft key. You will hear a conformation tone. The base information will be deleted. When replacing the base is complete, "Please Register" appears, register the handset to the new base.
If your handset is reading out of range. Check the the main base and make sure you unit has power. This can be done by placing the handset in the main base to see if the charge in use light comes on.
If your main base isn't getting power please make sure the ac adapter is plugged in and is warm to the touch. If not the ac adapter would be damaged.
To resolve out of range follow the below steps.
Press and hold the end key.
Press and hold the # key.
Release the keys and select replacing base and press select.
You will see Replace base?
Select Yes and press select.
Now place the handset on the base and it should register to the base and allow for calls to be made.
Jan 23, 2008 | Uniden CXAI5198 Corded Phone
Can not get the second handset to register to the base
This is the registration procedure
Step 1: press MENU-6 and select 3 “SET BASE”
Step 2: press the REG key on the master base
Step3: press register to finish the registration procedure.
• After the registration complete, handset 11 and handset 21 can
2-WAY intercom with each other
If issue persists reset the unit start registration by using 2nd unit that currently unable to register. if issue continues please inform for further troubleshooting
Good Luck
Jan 01, 2008 | EnGenius SN 920 Ultra Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
ID Conflict with Base 1 error
hold the volume and intercom buttons together the in use light will come on and then go to menu on handset press 6 then 1 to regester that should work i just talked to a friend with a telecom buisness and he told me what to do with mine good luck
Jan 08, 2007 | EnGenius SN 920 Ultra Cordless Phone
Panasonic KX TCD715 Cordless Phone Logo
659 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
