Question about Stihl Concrete Cutoff Saw Rewind Recoil Spring Ts 400
How to mix gas with 2 cicle for my ts 400 - Stihl Concrete Cutoff Saw Rewind Recoil Spring Ts 400
    Novelist:
  • 111 Answers
The bottle of the mix comes in many sizes. It should say right on the bottle of mix how many gallons of fuel need to be mixed with it. It will say MAKES X GALLONS.
Posted on Mar 30, 2011
My ts 510 is it self mixing oil to gas
so what is your problem?
many 2 strokes engines have a separate oil tank with a metering jet to get the correct fuel/oil ratio for any given throttle setting
with a distinct lack of details,to get a better answer you have to state all the details and exactly the problem you have
Jun 26, 2016 | GAS Motorcycles
Ts 510 has a oil tank along with gas tank. Why?
to oil the chain of course .all of them have the oil tank even electrics
Mar 09, 2015 | Garden
Carb settings for stihl ts 400
Standard settings: screw both in fully, unscrew H screw 1 full turn anticlockwise. unscrew the L screw 3/4 of a turn anticlockwise.
Aug 14, 2012 | Stihl Ts 400 Ts400 Carburetor Carb Rebuild...
First my Stihl Quikcut was getting too much gas now after rebuilding the carb it's not getting enough
Not sure who told you about the compression but that is not true, are you sure the throttle rod is actually pushing the throttle shaft open?
Mar 17, 2012 | Stihl Concrete Cutoff Chop Saw Clutch...
IS THE RESEVIOR UNDER THE SEAT FOR THE ENGINE OR GAS 2 CYCLE MIX
The reservoir Under the seat is for the two stroke mix, only. (tank feeds to the pump for the CCI or crank case induction)
Dec 17, 2010 | 1981 Suzuki TS 185
Does the TS400 need engine oil apart from 2 stroke mixture
Hello. No, the oil mix is designed to do all that is necessary. Stihl 50:1 two stroke engine oil or equivalent is recommended for proper operation, cheap oil does not have the additives needed too keep rings free and inhibit carbon build-up. Also do not use BIA or TCW rated oils, or any others with duel purpose ratings.
Thank you
Aug 22, 2010 | Stihl Concrete Cutoff Chop Saw Clutch...
Do four cicle engines need oil fuel misture
Hi. no oil is needed except in the oil tank. there is a separate oil fill point that you can use for the crank case oil section. no need to mix with fuel on the 4 cycle motor. Oil and gas are separate in this situation.
Apr 05, 2009 | Garden
Have a 98 Polaris 400 explorer 2 smoke. Could a blown head gasket cause a lean run and bog out at idle snap? Just currious if anyone has ever experienced this problem.
i have had this problem before. i just tried different gas. mine was a four cylinder and i used just gas so i switched to gas oil mix. try that.(different gas) (two cylinder-just unleaded gas) (four cylinder-gas oil mix).hope this helps.
Apr 02, 2009 | Polaris ATV
STIHL TS 400 won't start
I just repaired one with a similar problem--not getting enough gas. Two things corrected it and both were carb related. First I replaced a rather stiff diaphragm with a new one and second I reset the intake valve to allow more fuel into the carb. That solved it. Good luck.
The gas filter is weighted and should remain at the low point in the tank so it is an issue only when you are about to run out of gas--unless gas has been sitting in the tank for a long time. That can leave a film on the filter that can restrict fuel flow. Pull the fuel filter from the tank and scrap lightly on the filter. You will immediately note if there is a film on it. If so, replace the fuel filter.
Mar 15, 2009 | Hand Tools
Mix gas
You do not mix gas and oil in a kawasaki 400 motorcycle.
Nov 10, 2008 | 2008 kawasaki W 400
Stihl Concrete Cutoff Saw Rewind Recoil Spring Ts 400 Logo
179 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
