Question about Maytag Neptune MDE5500AY Electric Dryer
The heater and timer do not work
I have a Neptune drier, 8 1/2 years old. All of a sudden the timer and the heater stopped working.
  • adris May 30, 2008
    It helped to confirm that the heat and the timer are related. The problem was that the heater switch was pushed all the way up and and was not making contact to the thermostat. By bringing it down 1/4 of a inch it is now working.
    Thank you for your promptness.
  • 525 Answers
The timer won't advance unless te clothes are drying with heat.(No heat, no movement).
Check your fuse or breaker box to see if you have a tripped 30 amp breaker,(Flip breaker OFF then back ON), or blown 30 amp fuse.(Replace both 30 amp fuses to eliminate the possibility of being wrong).
If these check ok,(be certain), then you have a breakdown on the heat side of the 240 volt circuit, at which point, I would recommend calling a technician.
Let me know if I can be of any more assistance.
Posted on May 26, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
Jun 29, 2005
More results from
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Jul 08, 2008 | Maytag MDE2600 Electric Dryer
I have to replace the 8 hour defrost timer on my kitchen Aid KBRS22KWMS fridge every 2 or 3 years , is there a defect with these timers or is there a problem with my fridge that causes the defrost t
In a few cases, the timer is getting condensation damage from a poorly sealing door, or a missing shield. Commonly you'll see corrosion or stains on the timer when you remove it which would be a tattletale sign. Check for both when it fails next.
Jan 06, 2018 | KitchenAid Superba Architect KSCS25INSS...
No heat WD62 on drier or water heater
Check the thermistor is plugged in,,,it's next too heater
Jun 13, 2013 | Washing Machines
Pool timer can not get the plate to turn. Can lift the teeth but will not turn.
Timer is not identified.
Copy following link to help identify timer, and download possible manual.
And then add comment with clear description of timer, and what device the timer controls, and add if this is new timer, or timer that worked before and stopped working, and about how many years old the timer is.
Most timers come with limited 1 year warranty.
Oct 02, 2012 | Intermatic Aboveground Pool Timer Twist...
The lights that are attached to my sylvania digital wall switch timer SA170 flash. I changed the batteries in the switch a month ago.
If timer worked correctly in the past, and suddenly stopped working, then manual says to push the reset button.
Following link has manual.
I test timers, and most in-wall, and plug-in timers have 1 year limited warranty, although some last 5-7 years. When timers go bad, they are replaced. Sylvania is a good brand.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
After 7 years working properly, the event button has stopped working. There is no way to start the load in manual, or to change the program... What can I do?
You posted under EH40 Intermatic programmable timer.
EH40 Manual:
1) EH40 uses size A battery. Replace battery.
2) Reset the timer: Press and hold reset button for several seconds
3) Contact Intermatic because they are aware of specific problems with specific timers
4) Other folk have reported EH40 and EH10 last about 3 years.
EH40 has 1 year limited warranty.
I test timers: 7 years is reasonable run for inexpensive electronic time switch.
5) For longer lasting timer, consider Next Generation: battery is replaced every 8 years
Feb 28, 2011 | Intermatic EH40 - Electronic Water Heater...
Dryer does not stop, time not working
33003028-2 Timer Control Board is the most likely cause. Expensive and may be worth looking into a replacement drier. Hope this answers your question, Let me know if I can help you better. I do have all the info and photos at your request, Sea Breeze
Jan 25, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
My dryer is not rotating, heater is working. It is
sounds like a belt and the heating eliminate
Sep 26, 2009 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
61 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
