Question about Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive
Verbatim usb 160 external hard drive.
My new usb 160 hard drive no work when connect to my computer, only flash de blue light.
  • happybanana Jun 04, 2008
    My verbatim 160 GB firewire/usb portable hard drive does not mount itself when I connect it to my Mac powerbook G4. Only blue light comes on.
  • 4 Answers
That model doesn't have an external power supply port.
Posted on Feb 23, 2010
    Problem Solver:
  • 8 Answers
Try getting an external power supply from Verbatum. The drive might not be getting sufficient power from the USB port.
Posted on Dec 31, 2008
I have a Verbatium USB160 S/N JH8Y01 When I plug it into my laptop all I get is a flashing light on the drive. It did work at one time and I was able to back up to it. I read that the usb cable that came...
Does the drive have external power (D.C.) adapter? If not try to use a 2 ended usb plug to make sure the drive is being powered up. Does the computer see the drive? go to my computer\manage\diskdrives
Jul 12, 2011 | Verbatim 160GB USB FireLite: The "drive...
No computers will recognize my externaml Hard drive. Its model number is usb160. whenever i plug it in to anything, all it shows is a flashing blue light. Can you please help?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 26, 2010 | Verbatim 160GB USB FireLite: The "drive...
Verbatim 320 gb usb external hard drive stopped working.When the device is connected the blue led light is on.But computer is not recognizing.Help me.
* the USB cable
* the power-adapter
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 11, 2010 | Verbatim VER95327 USB Hard Drive
Hello, my external harddrive (Verbatim, 500GB USB/FW800) stopped working. When connected the blue LED lights up. After 3 sec it goes into flash mode. The HHD makes a clicking sound. The MAC Hard disc...
> the HDD makes a clicking sound.
That's a very bad sign. :-(
> find a way to rescue the [files]
Search online for a professional "data recovery service". For a significant fee,
they can repair your disk-drive, just long-enough to copy your files onto a brand-new disk-drive.
Nov 03, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I bought a verbatim 320 model. The blue light flashes on and off but the usb never loads. I can hear the drive wanted to boot but it just flashes on and off. I'ts able to work in my computer if I keep...
It seems that the disk-drive is "dying".
If it works, at least a bit, copy all the files from it onto your C: drive, or burn the files to DVD-writable disk(s).
Then, exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Verbatim 160GB USB FireLite: The "drive...
Hey there not sure if both usbs on this dual cable are to be plugged into my PC. The drive keeps flashing a blue light but my computer is not recognising it.
In most case's only one USB needs to be connected, but you need to load the driver for it from the disks which you would have received for it.
Hope this helps.
Thanks
Jason
Oct 14, 2010 | Verbatim 160GB USB FireLite: The "drive...
Hi! I stored files, docs, and pics, on my Verbatim Ext. Hard Drive USB 2.0 awhile back. I now want to update it. When I go to "shortcut to Verbatim" I get a Nero BackItUP Archive File page. When I...
Connect the external drive.
Open 'My Computer'.
One of the icons should be associated with the external drive.
Double-click the icon to "open" the external drive, to show the files/folders on the drive.
Oct 05, 2010 | Verbatim External, USB 2.0, 750GB...
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean?...
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Jul 18, 2009 | Verbatim 160GB USB FireLite: The "drive...
My Verbatim 320GB portable drive will not work with my iBook G4
Called Verbatim support and they said it is a power issue. They will send you a USB Y cable to get power from both USB ports. Hope it works.
Jun 29, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive Logo
2,163 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
